how do you.....
Old Jul 22, 2008 | 11:35 AM
Schlager's Avatar
Schlager
Default how do you.....
in disconnecting the tank..... the tube that runs from one side to the other under the front\\; how do you disconnect that w/out ruing the clamp or hose?
&nbsp\\;
&nbsp\\;
in disconnecting the wire harness for doing internal wiring... how do you disconnect the grey harness connection "thingy" under the tank?
Old Jul 22, 2008 | 11:53 AM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
Default RE: how do you.....
The clamps are crimped on at least they were on mine so its a cut off only deal.&nbsp\\; Just get a couple of new hose clamps from the local auto parts store and don't worry about them.
The gray thingy has a release latch.&nbsp\\; Push the button and it comes apart.
Old Jul 22, 2008 | 12:33 PM
story808's Avatar
story808
New clamps and hose... there cheap may as well change them, Have some plugs ready lots of gas gonna come out of there, another set of hands are helpful too?
Old Jul 22, 2008 | 12:34 PM
Schlager's Avatar
Schlager
why new plugs?
Old Jul 22, 2008 | 12:46 PM
story808's Avatar
story808
not sparkplugs,,, lol plugs to plug the cross over gas line, when you take that off gas will flow from the cross over on both sides. \\
Old Jul 22, 2008 | 01:03 PM
ORIGINAL: story808
not sparkplugs,,, lol plugs to plug the cross over gas line, when you take that off gas will flow from the cross over on both sides. \\\\\\
LOL, aint that the truth. I drained and eve tried to suck all the gas out before I pulled mine. The bike and me both still got a gas bath from what was&nbsp\\;left over.
Old Jul 22, 2008 | 01:04 PM
Schlager's Avatar
Schlager
gotcha! &nbsp\\;&nbsp\\; I already disconnected the braided main line &amp\\; allowed the fuel to drain overnight.&nbsp\\; Im hoping theres not much left.
Old Jul 22, 2008 | 01:07 PM
Believe me, there is a bunch left. Take a flash light and shine it into the tank toward the front and you should see there is a pint or more left in. The fuel line can only drain just so much without the pump running and even then its pickup is well above the real bottom of the tank.
Old Jul 22, 2008 | 01:11 PM
If your bike is fuel injected and you disconnected it at the tank its not supposed to drain anything at all. The fitting is like that used for air lines and shuts off automatically when the line is removed.
Old Jul 22, 2008 | 07:28 PM
mojojones's Avatar
mojojones
I've had my tank off several times for painting, numerous bar changes etc. and the hot ticket is mini vise grips.&nbsp\\;I keep a small tube that fits over the tank nipple with a bolt in one end to block the&nbsp\\;nipple side, and a pair of mini visegrips to crimp the crossover hose. Since&nbsp\\;i changed to the braided crossover I can't crimp anymore, but&nbsp\\;i keep a 4 foot section of garden hose leading to a gas can to catch the excess.
&nbsp\\;If you are internally wiring your bars, make sure you have a manual&nbsp\\;and do a search on the forum for removing the wiring harness&nbsp\\;from the plugs.&nbsp\\;The procedure has been documented several times.
Good luck!
J-Dog
May 21, 2011 03:44 PM
LVRider
May 26, 2009 07:44 AM
hogcrzy
Aug 3, 2008 12:11 PM
sulkaman
Exhaust System Topics
Jul 20, 2008 06:14 PM
crazytrain1
Jun 17, 2008 11:33 PM
