Pipes (no luck with search)
Old Jul 25, 2008 | 08:23 PM
If_not_now_When?'s Avatar
If_not_now_When?
1st Gear
Default Pipes (no luck with search)
I used the search function and I can't find this info...
&nbsp\\;
Will 2000-05 deuce or fatboy pipes fit on a 1999 softail standard (evo)?&nbsp\\; I can't get an answer to this.
Old Jul 25, 2008 | 11:07 PM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
Default RE: Pipes (no luck with search)
I seriously doubt it, Twincam engines are very different from EVO's for starters and I believe that the frames changed some of the dimentions between the change over. So even if the pipes could be mounted tomthe heads the odds are that they would not fit the mountings on the frame.
Old Aug 9, 2008 | 11:21 PM
TerryFXST's Avatar
TerryFXST
You are correct, they won't fit the frame mounts. This is easy to overcome with some drilling and tapping. I'm working on this right now and will post some pics as soon as I'm done.
sgr60
EVO
Mar 5, 2017 08:48 AM
ibmikexxx
Exhaust System Topics
Feb 19, 2013 07:44 PM
Jinxie
Custom Models
Jun 26, 2008 12:55 AM
kawsakimx6
Nov 12, 2007 06:40 PM
mcristia
Apr 6, 2006 12:45 AM
