Deluxe fork hopping on decel ??
Old Jul 27, 2008 | 09:32 AM
Hidalgo's Avatar
Hidalgo
Default Deluxe fork hopping on decel ??
My '08 Deluxe has a slight "hop" in the front during a deceleration especially in a curve.&nbsp\\; This seems to be usually around 35-40 MPH.&nbsp\\; Doesn't matter if the brakes are on or not.
&nbsp\\;
Suggestions?
Old Jul 27, 2008 | 09:51 AM
commander112's Avatar
commander112
Default RE: Deluxe fork hopping on decel ??
I don't completely understand your question but are you saying the forks appear to be sticking a bit?&nbsp\\; Perhaps it is fork seals or maybe a leak in fork oil?&nbsp\\; Look at the bolt at the bottom of the forks for leaks.
&nbsp\\;
Mark
Old Jul 27, 2008 | 09:59 AM
commander112
Also, stay off the brake in a turn.&nbsp\\; You are asking for trouble by doing this and are taking away from the bike's ability to turn.
&nbsp\\;
Mark
Old Jul 27, 2008 | 06:53 PM
Other Sheep's Avatar
Other Sheep
Almost sounds like the tire is a little out of balance. On decel youre loading the front end, making it heavier, so that may be why youre only feeling it then. Turning can also magnify the feeling. Have you put new tires on recently or maybe lost a wheel weight?
Old Jul 28, 2008 | 06:13 AM
bax467's Avatar
bax467
fork oil level may not be equal between the two legs.steering head bearing?
Old Jul 28, 2008 | 09:14 AM
the salt's Avatar
the salt
Check this thread.... http://www.HDForums.com/m_3604724/tm.htm
yandeltx
May 31, 2012 08:38 PM
saltydawg
Mar 17, 2009 03:30 PM
WVleo
Jul 19, 2008 12:51 PM
baxter
Jul 3, 2008 05:58 AM
forestfarm
Jun 27, 2008 09:45 PM
