Installing fork gaitors. need advice please
Old Jul 1, 2008 | 08:25 PM
baxter's Avatar
baxter
Default Installing fork gaitors. need advice please
&nbsp\\;I just got a nice pair of gaitors and i want to install them RIGHT NOW! haha.&nbsp\\; whats the easiest way to get these things on? am i gona have to remove the lowers?&nbsp\\;&nbsp\\;
Old Jul 1, 2008 | 08:27 PM
VenturaChop's Avatar
VenturaChop
Default RE: Installing fork gaitors. need advice please
take front tire off&nbsp\\;&nbsp\\; slide off legs&nbsp\\;&nbsp\\;&nbsp\\;&nbsp\\;&nbsp\\;&nbsp\ \;&nbsp\\;&nbsp\\; put on gaitors&nbsp\\;&nbsp\\;&nbsp\\;&nbsp\\;&nbsp\\;&nb sp\\; but it back together
Old Jul 1, 2008 | 09:22 PM
JRK5892's Avatar
JRK5892
lift bike, undo brake caliper, break the trees loose and slide down your tubes... put fork boot on, then slide them back in, you can go about 1in down (though) the trees if you are not running a front fender and not drop down to much where you scrape and crap, bolt it all back up be sure to use the loctite... both ways work
Old Jul 1, 2008 | 09:47 PM
baxter's Avatar
baxter
ORIGINAL: VenturaChop
take front tire off&nbsp\\;\\\\\\;&nbsp\\;\\\\\\; slide off legs&nbsp\\;\\\\\\;&nbsp\\;\\\\\\;&nbsp\\;\\\\\\;& nbsp\\;\\\\\\;&nbsp\\;\\\\\\;&nbsp\\;\\\\\\;&nbsp\ \;\\\\\\;&nbsp\\;\\\\\\; put on gaitors&nbsp\\;\\\\\\;&nbsp\\;\\\\\\;&nbsp\\;\\\\\ \;&nbsp\\;\\\\\\;&nbsp\\;\\\\\\;&nbsp\\;\\\\\\; but it back together
&nbsp\\;
&nbsp\\;
do the sliders just come loose that easily?
Old Jul 1, 2008 | 10:20 PM
Mr. Blonde's Avatar
Mr. Blonde
The sliders are the lower part of the fork. Remove the forks from the trees and slide them out of the trees and install the gaitors. Put together in reverse order. You don't have to pull the front wheel, just the brake caliper from the left slider.
&nbsp\\;
&nbsp\\;
Old Jul 1, 2008 | 10:46 PM
baxter's Avatar
baxter
are the only bolts you have to loosen the ones on the tree clamps?&nbsp\\; and does it scratch the tubes when you slide em down thru the trees?
Old Jul 1, 2008 | 11:02 PM
Mr. Blonde's Avatar
Mr. Blonde
Spray WD-40 on the tubes, get that thing far off the ground and slide 'em out. If you can't get it high enough pull the front wheel and do them one at a time.
Old Jul 2, 2008 | 02:55 AM
baxter's Avatar
baxter
sounds like a good plan. thanks im on it tommorow.
Old Jul 2, 2008 | 07:14 AM
ehretja's Avatar
ehretja
Baxter, post your results and any snags you ran into. I'm looking to do the same thing. By the way.. i love your bike man. It's original and bad a$$!!
Old Jul 2, 2008 | 09:19 AM
JRK5892's Avatar
JRK5892
dude it is crazy easy! it is 6 bolts, slide down the tubes put back on... i lifted my bike with a cherry picker and did it in the back of a machine shop while i was waiting for a buddy to get off work, it is easy!
