2008 Fatboy detachable backrest signal relocation kit help
Old Jul 29, 2008 | 03:37 PM
devo5566's Avatar
devo5566
Default 2008 Fatboy detachable backrest signal relocation kit help
How hard is it to do and should I attempt to do it myself. I am not the best when it comes to doing&nbsp\\; electrical myself but am always willing to give it a shot.
&nbsp\\;
Thanks for the advise.
Old Jul 29, 2008 | 03:58 PM
topefisher's Avatar
topefisher
Default RE: 2008 Fatboy detachable backrest signal relocation kit help
Its a long winded excercise for the result you see.
You need to unfasten and very carefully lift the rear fender at the rear and wedge /pack it up in the air whilst you work under it leaving it part fastened towards the front.
&nbsp\\;\\\\\\;\\\\\\\\\\\\\\;\\\\\\\\\\\\\\\\\\\\ \\\\\\\\\\;
The elctrical side requires you to cut the wires as per instructions, crimp on the special in line connectors with a decent crimping tool and at a later&nbsp\\;\\\\\\;\\\\\\\\\\\\\\;\\\\\\\\\\\\\\\ \\\\\\\\\\\\\\\;stage&nbsp\\;\\\\\\;\\\\\\\\\\\\\\ ;\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\;heat shrink those same connectors.
Special slotted nuts are used for securing the indicators and clearing the wires when re-assembling. A lot of care is needed to avoid scratching the Fender and trapping the wires.
I did mine with the wheel actually removed as I was fitting new wheels at the same time so access was much better.
I you feel you can cope easily on this basis you should be fine.
With the wheel removed it took me about 1 1/2 hours from memory - not a quick job I am afraid.
Old Jul 29, 2008 | 04:12 PM
eagle1eye's Avatar
eagle1eye
Just did mine. I cut the sideplates till they fit around the stock signal standoffs. It doesn't take much.
Old Jul 29, 2008 | 04:30 PM
topefisher's Avatar
topefisher
Eagle1eye I don't think that can be done on an 08 model. You may be able to cut the sideplate but you would also have to cut away and destroy the main working part of the quick release on the detachment mechanism.
Old Jul 29, 2008 | 08:53 PM
tk353's Avatar
tk353
get you one of these and you dont have to relocate and you dont have those unsightly side plates
&nbsp\\;
http://www.haulenass.com/sissy_bars_backrests
Old Jul 30, 2008 | 07:48 AM
nhbouncer's Avatar
nhbouncer
You don't have to loosen the fender at all either you can reach in from the side of the fender with your hand to remove the wires from the clips under the fender.&nbsp\\; I also suggest not using the butt connectors they supply but to solder and shrink tube the wire splice.
Old Jul 30, 2008 | 02:36 PM
topefisher's Avatar
topefisher
You need to loosten the fender to get the fixings in place for the hollow re-location studs and their securing nuts.
&nbsp\\;\\\\\\;
How did you manage this without lifting the fender clear of the stays?
Old Jul 30, 2008 | 05:54 PM
Loud1's Avatar
Loud1
If you do one side at a time you can just take the fender strut off one side and never have to move the fender . Less chance of scratching something and it lines back up perfectly if you do one strut side at a time
Old Jul 31, 2008 | 10:55 AM
duxsrus's Avatar
duxsrus
I did mine without moving the fender as well.&nbsp\\; The instructions were about worthless.&nbsp\\; Hardest part was getting the wire through the new stem.&nbsp\\; Found liquid dish soap was the answer.
Old Jul 31, 2008 | 08:51 PM
nhbouncer's Avatar
nhbouncer
ORIGINAL: duxsrus
I did mine without moving the fender as well.&nbsp\\;\\\\\\; The instructions were about worthless.&nbsp\\;\\\\\\; Hardest part was getting the wire through the new stem.&nbsp\\;\\\\\\; Found liquid dish soap was the answer.
Agree with the instructions being the biggest bunch of s**t ever pretty much toss them out.&nbsp\\; And you will most certainly need some lubrication to get those wires in there they didn't spare any room at all.
