squeak in swingarm
Old Aug 4, 2008 | 09:27 PM
jeff306's Avatar
jeff306
Default squeak in swingarm
hi, i have an 03 standard and when i push down and release on the rear end it squeaks. I lubed what i could and its still there. anyone else have this?
Old Aug 5, 2008 | 07:45 AM
a4x4high's Avatar
a4x4high
Default RE: squeak in swingarm
I had the same problem on my 06 heritage .I just removed and disassembled the shocks to put on a lowering kit and found that the shocks had alot of dirt in them around the spring .I cleaned out all the dirt and reinstalled with lube on the bolts were the bushings ride and the noise is gone.
Old Aug 5, 2008 | 10:43 AM
Harley_Dude's Avatar
Harley_Dude
Yep its most likely your shocks. Hit them with some lub (WD40).
Old Aug 7, 2008 | 04:20 PM
jeff306's Avatar
jeff306
OK, thanks guys. I will do that and see what happens.
Old Aug 8, 2008 | 07:03 PM
jeff306's Avatar
jeff306
Thanks a bunch to both of you. Lubing the shocks worked, but I had to loosen the bolts in order to spray the lube onto the bolt and in it's hole. Nice and quiet now.
Old May 11, 2010 | 03:06 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
Glad I found this ancient post. I was getting worried as my bike was squeaking this am. I guess I'll hit the shock bolts with WD 40.
bran48
Mar 12, 2014 03:22 PM
little squirt
Feb 2, 2013 12:50 PM
tripwire759
Jan 15, 2012 01:27 AM
joechief
Aug 28, 2006 08:11 PM
lmundy
Feb 2, 2006 01:00 AM
