Trick to installing Rear shocks
Old Jan 14, 2012 | 02:33 PM
tripwire759's Avatar
tripwire759
Default Trick to installing Rear shocks
I'm in the middle of trying to put the Burnout Softail Lowering Kit on my Deluxe. I pulled the shocks but I am having a Hell of a time getting the right shock back in. What is the trick guys?
Old Jan 14, 2012 | 02:39 PM
anubisss's Avatar
anubisss
Raise or lower the swing arm to allow room for the shock to go in.
Drew
Old Jan 14, 2012 | 03:13 PM
tripwire759
Still not enough room doing that Drew. The left will go easy but the right is real tight.
Old Jan 14, 2012 | 03:41 PM
PanHeadRich's Avatar
PanHeadRich
Are both mounts of the shocks adjusted evenly. From what you're saying it sounds like maybe one side is adjusted longer than the other?
Old Jan 14, 2012 | 06:23 PM
tripwire759
No Rich I was putting them one at a time and was following the directions. I got them both in but it was a royal bitch to do. Now all I need is a 15/16 box wrench cut in half to make the final adjustments.
Love the way it looked slammed without the shocks. Time to start saving for a shotgun.
Old Jan 14, 2012 | 08:22 PM
Sgt_Jim's Avatar
Sgt_Jim
Idk if it's the same on the deluxe, but I actually had to install the right shock from the left side, and kind of wiggle it in to the slot, meanwhile I had to physically lay under my rear tire (bike was up on a jack)..and i used my chest to move the swingarm up and down until it fell in to place
Old Jan 14, 2012 | 08:29 PM
PanHeadRich
I hear ya, I'm doing the same. I'm just trying to determine their priority ... function vs. form
Old Jan 14, 2012 | 09:52 PM
byersmtrco's Avatar
byersmtrco
It's a PAIN. I actually used the cycle-jack and a floor jack, adjusting
the swing arm. It took a few tries. Putting the stock shocks back in was
easier than those 422 things. I had those on for one long ride. Rode like a brick.
Old Jan 15, 2012 | 01:27 AM
oct1949's Avatar
oct1949
That's diff, every post in here has always been that there were great shocks
1st neg I've every seen on them.
Odin510
May 6, 2015 10:09 PM
Aussiemadness
EVO
Jan 3, 2015 08:01 AM
star2nv
May 30, 2013 02:11 AM
Mordrapheus
Jun 16, 2009 10:44 PM
OneBlackFly
May 9, 2007 08:25 PM
