softail Shocks
Old Jan 3, 2015 | 01:15 AM
Aussiemadness's Avatar
Aussiemadness
Default softail Shocks
G'day All.
Well the old Heratage is going well, fixed up a few little things.
But!....She is way to low in the backend, I am scrapeing pipe's/floorboards just taking it easy.
So, apart from unbolting the rear of the shocks and unscrewing the eyelet is there any other way to do it? Hopefully there is. Photos below.
Cheers
Dave
Attached Thumbnails softail Shocks-20150103_174446.jpg   softail Shocks-20150103_174519.jpg
Old Jan 3, 2015 | 01:55 AM
SeaZund's Avatar
SeaZund
thought that was the only way to adjust them?
Old Jan 3, 2015 | 01:58 AM
Spanners39's Avatar
Spanners39
To raise the back end you need to screw the eyelet in as Softie shocks work in reverse to a normal shock, so you shorten the shock to raise the back end. You may even have a lowering kit fitted which essentially extends the shock eyelets.
Old Jan 3, 2015 | 02:31 AM
Aussiemadness
Thanks Spanners, that makes sence now you explained it...screw the eyelet in.
So I have to jack her up and unbolt the eyelet and screw them in.
Cheers.
Dave.
Old Jan 3, 2015 | 05:02 AM
Schex's Avatar
Schex
On most lowering kits , you don't have to unbolt the eyelet, you just loosen the locknut and turn the hex behind it which turns the whole assembly inside the shock, to screw or unscrew the eyebolt.
http://www.progressivesuspension.com...0Eye%20Kit.pdf
Old Jan 3, 2015 | 08:01 AM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Granted the picture is of a 2000 and later shock but the procedure is the same
http://www.progressivesuspension.com...hd_softail.pdf
I adjusted mine while they were bolted on the bike.
sgr60
EVO
37
Jan 23, 2017 05:39 PM
tripwire759
Jan 15, 2012 01:27 AM
Mr1986FLST
EVO
Aug 10, 2010 03:08 AM
82flh
Apr 2, 2010 09:18 AM
tmitchellof PG
Jan 28, 2007 02:17 AM
