ThunderMax Digital Speedo
Old Aug 8, 2008 | 02:26 PM
dblduce's Avatar
dblduce
6th Gear
I have one of the Tmax speedo's
Things you might not have noticed yet:
1) In direct sunlight you'll have to guess what your speed is. The glare makes it un-readable.
2) After 9 months I still haven't got the milage thing to work. I thought I figured it out but it seems not. If I did configure it right then it fluctuates wildly from low teens to 100+ MPG.
3) I lost one of the lights in the MPH readout
4)when I rolled over from 19, 999 miles it wne to 10,000 miles instead of 20,000
I bought it for my 07 Duece also thinking it would be better looking than a clamp on tach. If I had to do it over again I would keep the $ and go with a cheaper clamp on style.
The other thing to watch out for is that if your looking at a bike that has one of these installed, you can reconfigure the mileage and set it to anything you want so be warned!
Old Aug 8, 2008 | 03:38 PM
aviscomi's Avatar
aviscomi
Yeah, I notice that they do suck in sunlight! But as I said in my intial review, "I would not recommend these speedos", especially at the $450= pirce tag.
Old Aug 8, 2008 | 11:18 PM
Cheesecake's Avatar
Cheesecake
I'm with you!
I removed my tank when i installed it, I put a new set of bars and ran the wires internally, i started with an empty tank and set it to zero in the config. mode.... i then put a little gas in rode to the station, filled up that tank.
I went into the config. mode and could not get the fuel gauge numbers to change... it reads .6 or .7; The instructions say to use both the "set button" and the "trip button" as soon as i touch the "trip button" it goes to the odometer...
I also tried to set it in the standard mode with no luck either....
If you can't tell i am getting a little frustrated!
Old Aug 9, 2008 | 06:56 AM
aviscomi's Avatar
aviscomi
Originally Posted by Cheesecake
I'm with you!
Sounds like you're not in the CONFIG Mode; with the bike turned off, hold down the CONFIG Button and turn the bike on. Then just scroll to the desired Fuel Mode you're trying to set.
outfishin35
EVO
13
Jul 6, 2017 11:46 AM
golfblues
Dyna Parts
Oct 12, 2013 09:04 PM
golfblues
Softail Parts
Oct 12, 2013 09:02 PM
bluharley
EVO
Oct 2, 2013 08:39 AM
SuperFastGlide
Nov 8, 2009 04:24 PM
