rocker c seat question
Old Aug 11, 2008 | 06:50 PM
tags's Avatar
tags
Default rocker c seat question
does anyone elese have a problem getting those gay studs to line up with the rubber gromet? i tried adjusting the black plastic pice to help with alignment.no luck so i took the studs off..i think it may have droped my seat hight a fraction too. im liking the rockin bobber stage one more and more..just a little steep at $850.
Old Aug 11, 2008 | 09:01 PM
Windeed's Avatar
Windeed
I haven't had any trouble with the seat studs lining up with the rubber grommets. There may be some adjustment where the hinge at the front of the seat attaches to the frame but don't know for sure. Be careful, removing the studs may create a safety problem with the seat moving around unexpectedly and you don't need that.
Old Aug 12, 2008 | 08:56 AM
RockerMike's Avatar
RockerMike
If you don't need the trick seat just get the FXCW seat and put it on. It will lower you and is more comfortable. Worked perfectly for me.
frozensoul
Oct 9, 2011 06:59 AM
ao2slabaugh
Mar 18, 2010 10:16 PM
DevilDogg
Jun 11, 2009 06:48 AM
bigjoe21
Apr 19, 2009 09:12 PM
cccsclark
Dec 6, 2008 08:05 AM
