heritage sideplates
Old Aug 17, 2008 | 11:39 AM
mnickhd's Avatar
mnickhd
Stage II
Default heritage sideplates
I need to remove the sideplates so that I can get at the sissybar attachment screws to add a luggage rack. How do I remove the sideplates. There are several bolts there including the ones for the saddlebags. I don't want to break anything.
Old Aug 17, 2008 | 02:12 PM
Chief40al's Avatar
Chief40al
I just did that 2 weeks ago.
Remove bags
Remove studs(bag bracket mount)
Brackets inside fender will drop out
Lift sissy bar
Remove screws(torx 27)
Install rack
reinstall sissy bar and bags.
Enjoy the ride.
Old Aug 17, 2008 | 02:14 PM
FGC's Avatar
FGC
you need to remove the bags--very easy 3 bolts including the support arm.5 min job
Old Aug 17, 2008 | 02:36 PM
mnickhd's Avatar
mnickhd
Stage II
Thanks for the reply. Do the bag studs just screw out? I was using a lot of force and they didn't move so I was afraid of breaking the stud off.
Old Aug 17, 2008 | 03:57 PM
JoeFLHX's Avatar
JoeFLHX
LOck tight probably, use a cheater bar, leverage. Also the frame may move when you take out the bolts, make sure they line back up. If not stick something in the to align them or you may strip a bolt, experience.
TxCowboy
Apr 27, 2012 11:53 AM
wanabe
Mar 8, 2010 05:44 AM
True Grit
Oct 30, 2009 01:12 AM
SunDevilBiker
May 10, 2007 03:18 PM
06Heritage
Apr 7, 2006 04:24 PM
