Anybody has an opened air cleaner?
Old Aug 25, 2008 | 12:32 PM
128auto's Avatar
128auto
100% air filter oil, I have checked the banjo bolts and they are fine.
Old Aug 25, 2008 | 12:43 PM
deadman77's Avatar
deadman77
If you are trying to get it painted red then you are using too much.
A fine mist is all you need.
MikeM
Old Aug 25, 2008 | 12:47 PM
jknowlton's Avatar
jknowlton
Originally Posted by sportncruise
You obviously haven't cleaned and oiled it yourself yet and still have the factory oil installed at the proper level.
When you do it yourself just use a fine amount!
thank you will keep that in mind when im cleaning it..appreciate it.
Old Aug 25, 2008 | 12:53 PM
*NIGHT TRAIN*'s Avatar
*NIGHT TRAIN*
Originally Posted by coop57
Mine did the same above 70 MPH, I thought it was filter oil but it turned out to be breather oil weepin past the banjo fittings.
That's one of the reasons I switched from the SE to the AN Big Sucker, no banjo fittings, no mess. That, and the fact that I can clean the filter with the K&N kit, as opposed to throwing away the SE paper filter. And yeah, LIGHT on the oil...
Old Aug 25, 2008 | 01:18 PM
128auto's Avatar
128auto
Right on, that's what I did. lol
MikeM
Old Aug 25, 2008 | 10:50 PM
128auto's Avatar
128auto
Just came back from a 50 miles highway ride, no more oil dripping. I will use minimal air filter oil from now on. Thanks guys!
Old Aug 26, 2008 | 05:48 AM
rns99's Avatar
rns99
You don't need to keep oiling it all the time. It only needs oil when you clean it.
When cleaning it you must let it dry completely be fore reoiling it. If you are cleaningit all the time because it is not red you are cutting down on the life of the filter.they work fine when they turn gey.
Old Aug 26, 2008 | 08:47 AM
128auto's Avatar
128auto
I have a trick to dry the air filter, wash and rinse, put it on the top of my car defrost vent, start my car and turn on the heater to mild hot, it takes 10 mins to dry, there you go!
Old Aug 26, 2008 | 08:51 AM
EvEr34's Avatar
EvEr34
No oil problems here....as some have said you probably putting to much oil.
Old Aug 26, 2008 | 01:41 PM
tripwire759's Avatar
tripwire759
I would cut the oil down a little, but what you need to worry about is the rain.
