Transmission Fluid...Does it Darken?
Old Aug 29, 2008 | 06:11 AM
FXDSE2's Avatar
FXDSE2
Default Transmission Fluid...Does it Darken?
After being do &!$$ed because of the loud 5th gear noise in my 2007 Heritage (5,000 miles on it) I took the advice of the members here and changed my Tranny fluid to Redline (which is really red and filled with microparticles). After letting the transmission drain all night I noticed it had a dark brown color and had the same kind of smell that darkened engine oil has. Maybe it is my ignorance but should it turn that dark? My engine heats to about 225 on the road, exactly where it should be and it should not burn at that low of temperature. Is this normal or is there something I should be watching out for?
FXDSE2
Attached Thumbnails Transmission Fluid...Does it Darken?-img_0051.jpg   Transmission Fluid...Does it Darken?-img_0033.jpg   Transmission Fluid...Does it Darken?-img_0128.jpg
Old Aug 29, 2008 | 10:54 AM
Other Sheep's Avatar
Other Sheep
Mine will darken some after 5,000 miles but it always smells like gear oil, nastier smell than an engine oil. What kind, brand of oil was in your tranny?
Old Aug 29, 2008 | 01:41 PM
FXDSE2's Avatar
FXDSE2
Original Harley tranny fluid...cost me $20,000 for that quart of tranny fluid and a big old bike to hold it. FXDSE2
Old Aug 29, 2008 | 01:47 PM
Cheesecake's Avatar
Cheesecake
did you change it at your first service?
Old Aug 29, 2008 | 02:06 PM
Bugger's Avatar
Bugger
Default On the dark side
The Stealer replaced my trans oil (07 Dyna 6 speed cruise drive) at 1K miles with HD Syn3. I drained it out last week with 4.5K on the odometer. The Syn3 was dark like thick coffee (cuban), no lattie please. The last bit looked contaminated, foamy cream color. The drain pan looked a little like a "B52" or Kalua and Irish Cream. The drain plug had a fuzzy head like a fuzzy naval. This is all getting me hung over.
Old Aug 29, 2008 | 03:19 PM
jimmers1817's Avatar
jimmers1817
Kalua is a good description. Sounds about normal to me. Wouldn't worry about it. Always some fuzz on the magnet.
Old Aug 29, 2008 | 03:27 PM
Bugger's Avatar
Bugger
Take two aspirens and sleep it off.
Old Aug 29, 2008 | 05:41 PM
FXDSE2's Avatar
FXDSE2
BUGGER hit it right on the nose...mine was exactly the same way and had a touch of the navel-fuzz also. Kalua or thick coffee would be a great description..poured it on the poison ivy and it did it in. I replaced it with Red Line 75/145 heavy duty and it took care of that 5th gear noise. The whole bike sounded more quiet other than the pipes. FXDSE2
jpowell490
Oil Archive (no new posts)
98
Jun 17, 2023 06:36 AM
Vinish
Nov 24, 2011 04:40 AM
Norton88
Apr 7, 2010 03:43 PM
Seaquester5
13
Jan 3, 2008 11:27 AM
bucs012
Sep 7, 2006 03:22 PM
