Help needed on handlebar wiring
Old Aug 29, 2008 | 04:36 PM
shad1340's Avatar
shad1340
One more thing...in the Softail manual, the info about all of the different plugs on the bike is after the tool section in the back. Didn't really understand why it was not included in the electrical section, but eventually found it anyway. Shad
Old Aug 29, 2008 | 04:50 PM
rubiconMike's Avatar
rubiconMike
Originally Posted by shad1340
If the plugs under the tank are the same as on my 07 Heritage, they will be Molex plugs. They do have two locks, a primary and secondary. I believe that it is the secondary??? that is pulled up about 1/8" from down inside the plug, then I used the pointed end of a large paper clip, inserted in the small hole just below the pin until you feel it "click", then pull wire from plug. Once you get the hang of it, all wires can be removed in matter of seconds. I just installed 14" apes and did not want but one solder splice on each side. Ended up being a very clean way to install. Shad
I went down to my local Harley dealership and was fortunate enough to get to talk to a technician in person about it.
You're description above is exactly what the technician told me. It is called a Molex connector and yes there is a primary and a secondary lock.
In the center of the connector there are two holes that have to be pulled up about 1/8" before you can push each of the individual wires out via the other lock. The first lock is the one that's giving me all the troubles ( two holes next to each other in the center of the connector). I can't get this one to pop up. Any hints as to how to get it to pop out?
Thanks,
Mike
Old Aug 29, 2008 | 05:15 PM
Cheesecake's Avatar
Cheesecake
Man I wish i would have taken pictures when i did mine....
I can invision in my head how its done... but putting it into words is another thing...
i used a small needle nose pliers to unlock the first one... it slid into the two holes and I just yanked on it gently ...
Old Aug 29, 2008 | 05:16 PM
shad1340's Avatar
shad1340
Default Handlebar wiring
Mike, I used a cotter key puller that has two slight bends at the end. The one with the 180 deg end would be perfect but the radius on the bend is too large to get engage the hole in the plug. Put it in one of the holes as far as it will go and twist slightly to wedge the end of the pick and then pull straight up. Don't be afraid to pull pretty hard and you'll find that it comes right up. You wont tear anything up and if you do, I spent $8.00 on a new plug. Remember too when you put the paper clip, or whatever you use into the hole below the pin, you will feel it bottom out. After the bottom, you have one more "click", then pull the wire free. Shad
Old Aug 29, 2008 | 05:19 PM
shad1340's Avatar
shad1340
Small needle nose pliers would be perfect. I could not find mine...
Old Aug 29, 2008 | 06:52 PM
drkenigma1's Avatar
drkenigma1
Hey Mike take pics. I wanna do the same to my Rocker. What are you doin'?? Changin' the turn sigs, the handlebars. If so what kind? And how did you empty the tank?
~Drk~
Old Aug 29, 2008 | 07:04 PM
drkenigma1's Avatar
drkenigma1
Ok use this product for your future electrical projects
http://www.jpcycles.com/ProductDetai...381-087&cs=All
Or JP Cycles web site product # 381-087
~Drk~
Old Aug 29, 2008 | 07:18 PM
Cheesecake's Avatar
Cheesecake
Drk....
maybe i'm an idiot... but i have one of them and it did not work for me....
but then again i'm into doing things the wrong way!! LOL!
Old Aug 29, 2008 | 07:23 PM
Nostalgic07's Avatar
Nostalgic07
Hey Mike...take a look at this file...It helped me to understand how it all works!! http://www.molex.com/cmc_upload/0/00...usermanual.pdf
Rob.
Old Aug 29, 2008 | 07:44 PM
rubiconMike
Thanks guys!!!
The needle nose pliers did the trick. The guy at the Harley dealershiip showed me a pick that had a hook on the end of it that he used so I went and bought one but I couldn't get that thing to work at all! LOL. Needle nose pliers and it came up no problem at all (then I felt like an idiot!).
Once I got the first lock popped out the second lock wasn't a big deal either.
Again thanks for everyone's help.
medicmouse
Electrical/Lighting/Alarm
Aug 2, 2017 09:46 AM
Dyna2007
Dec 27, 2009 07:34 PM
entourage
Oct 25, 2009 10:22 PM
GPHDXLC
Dec 26, 2008 12:56 PM
drogers
Jun 1, 2008 06:26 AM
