Belt Tension
Old Sep 12, 2008 | 06:51 AM
Guitarman52's Avatar
Guitarman52
Default Belt Tension
Did the 1000 miles service on my 09 Heritage. I used the belt adjustment tool to check the tension with the bike on the lift. I measured a hair below 3/4". The service manual says that is within range with the bike off of the floor. Since it is on the upper end of the adjustment, should I tighten it a little bit, or leave it alone.
Old Sep 12, 2008 | 07:05 AM
corona1cal's Avatar
corona1cal
if your service was just done leave it alone---seeing it a 09 take it back and ask your dealer--other wise you may be blamed if problems arrise later.
Old Sep 12, 2008 | 07:06 AM
corona1cal's Avatar
corona1cal
ps ---how do you put the large pic in the info area
Old Sep 12, 2008 | 08:00 AM
robzuc97's Avatar
robzuc97
I don't have an '09 manual & haven't worked on these at school but have a '97 and have worked on '06 FLSTC's & '07 FLSTN's. Are you sure the manual spec is 3/4" for rear belt deflection? My '97 is 3/8-1/2" on jiffy and the '06 is 1/4-5/16" on jiffy stand & 3/16-1/4" upright with wheel in the air. Is this a HD SM or aftermarket (i.e.: Clymer's, Haynes)? Or a post misprint?
Old Sep 12, 2008 | 10:09 AM
Guitarman52
Harley Service Manual for Softail Models - 99482-09
Jiffy Stand 9/16-5/8 in. (14.3-15.9 mm)
Vehicle upright with rear wheel in air 11/16-3/4 in (17.5-19.1 mm)
Old Sep 12, 2008 | 10:15 AM
maddawgchevy's Avatar
maddawgchevy
The large pic is part of your signature. Once you upload a pic that will fit, I had to play with it a lot you put the following comman in the edit signature block: [sigpic][/sigpic]
Old Sep 12, 2008 | 12:42 PM
sonar_chris's Avatar
sonar_chris
I would tighten it up some, put it in the middle of the spec, that way if for some reason, it streaches a little, youll be ok, and vice versa, it shrinks (unlikely) you will be good too.
markkoby
Oct 6, 2012 11:57 PM
jimdog1356
Jun 10, 2012 06:15 AM
freebyrd
Jun 22, 2009 12:27 PM
YellowHawk
Nov 3, 2008 03:11 PM
OnTheFence
Sep 1, 2008 08:43 AM
