Wobble in Springer Front End
Old Sep 21, 2008 | 03:10 PM
mdst's Avatar
mdst
Default Wobble in Springer Front End
2001 FLSTS has wobble between 35-40 MPH. Changed tire, rims not bent, all adjustments have been done. Can't get it to stop, any ideas?
Old Sep 21, 2008 | 03:18 PM
Reverend's Avatar
Reverend
Hi mdst,
Do you mean handlebar wobble or vibration? The wobble can be from other things, such as poor loading, loose head bearings, tyre pressures, wheels not in line and much more. If it's a front end vibration, it could be a poorly mounted tyre (check for lateral run-out at rim when revolved by hand etc), may also be an out of balance wheel/tyre but this is normally at 50mph ish.
Any use?
Old Sep 21, 2008 | 03:23 PM
Cheesecake's Avatar
Cheesecake
You should also check your spokes
I solved a little front end issue with a quick check and tightening of a few front spokes..
Old Sep 21, 2008 | 03:39 PM
mdst's Avatar
mdst
handle bar wabble
Old Sep 21, 2008 | 03:46 PM
Reverend's Avatar
Reverend
Standard ride heights? Wobble just started or simply got too much? What adjustments have you done? Always on one road or anywhere?
Old Sep 21, 2008 | 03:54 PM
hogdoctor's Avatar
hogdoctor
start with your steering neck bearings. They need preload to dampen out some of the oscillations. Check your rims for true, wheel bearings, swingarm bearings, axle torque,
if all this checks out, you may have a bulged or defective tire with a weak spot.
Usually a front wobble starts in the rear of the bike, so look into the rear tire/wheel carefully.
Hogdoctor
Old Sep 21, 2008 | 04:01 PM
mdst's Avatar
mdst
Spokes were tightned. Bottom rockers were adjusted. Happens anywhere.
Old Sep 21, 2008 | 05:29 PM
bigoscycles's Avatar
bigoscycles
check the neck bearings. tighten the nut and it will probably help.
Old Sep 21, 2008 | 06:10 PM
Reverend's Avatar
Reverend
Reckon it's knackered old son. Sell it to me dirt cheap..
Old Sep 21, 2008 | 06:41 PM
megawatt's Avatar
megawatt
Reverend,
It warms the cockles of my heart that a kind soul, such as yourself, is willing to take defective equipment off the the backs of the suffering. Carry on in your quest and keep the faith that there is a sucker born every minute...ya just gotta find him!
Or, maybe you should be ashamed of yourself...NAH!!
mdst, Good luck with the problem.
gnewman
Sep 10, 2012 09:56 PM
jadev
Apr 6, 2011 11:43 AM
Springer97
Apr 19, 2008 12:48 AM
Warden
Sep 6, 2007 01:20 PM
bgismo20
May 30, 2007 09:52 PM
