05' Springer Classic
Old Sep 2, 2007 | 12:36 AM
Warden's Avatar
Warden
Default 05' Springer Classic
Hello all, this is Mrs. wmko1 aka Bisquit-just borrowing the id-I need help before I take my bike to the stealer for some work. I went on a 120+ mile ride on Friday out on some country highways including some chip & seal, and noticed my bike having a slight vibration in the handlebars and a mild to moderate wobble sporatically when loose pressure was applied to my bars. I blamed it on the roads due to the grooves etc. I got to my destination safe and sound, looked over the tire just to make sure I didn't have nothing stuck in them, they were fine, they have about 5k on them so fairly new. I parked for the night woke up the next day to take off and now I have a more moderate wobble and also its a lot more consistent. Since the tire is fine, the wheel isn't bent,wheel balance is correct, I'm wondering if I possibly have a bearing trying to break lose or something, or maybe the front brake is trying to drag.....I am not a mechanic however just fairly mechanically inclined so just wondering if anybody else has any thoughts as to what the problem could be before I take it to the stealer for a diagnosis. Any help would be great and thanks in advance.
Old Sep 2, 2007 | 10:09 AM
Unibomber's Avatar
Unibomber
Default RE: 05' Springer Classic
I would bet my biscuits on the steering bearing nut. It just needs to be tightened. If the dealer has the right wrench it will only take about 20 minutes. My springer did the same thing on a road trip. This is something the dealers are supposed to check for if you bring it in at 500 miles like your supposed too with a springer. I do all my own oil changes, so its something to watch for. Shouldnt be a big deal. Let me know what happens.
Old Sep 2, 2007 | 11:39 AM
scorp58's Avatar
scorp58
check your spokes, this tends to happen when you have loose spokes
Old Sep 2, 2007 | 02:17 PM
bgismo20's Avatar
bgismo20
On my 05 springer classic it was a steering neck adjustment, they did it at my 10K and it stopped, im sure thats what it is
Old Sep 2, 2007 | 02:31 PM
Biscuit15's Avatar
Biscuit15
5th Gear
Appreciate the responses, checked the spokes, they are all tight. Checked the steering bearing nut I was able to get 1 1/2 turns out of it, can anybody tell me how tight this should be...as tight as possible,or just muscle tight?
Old Sep 2, 2007 | 03:40 PM
Biscuit15's Avatar
Biscuit15
5th Gear
Okay, thanks to all for help. Problem resolved, wobble/vibration is gone. The steering bearing nut being loose was obviously the only problem. After tightening "she" was back to being my same old baby. Just a little fired up because I just had my 20K service at the dealership and they obviously failed to check it, but neither did I. Lesson learned I suppose and I learned that I have one more bolt to check before I go out on the road. Thanks again.
Old Sep 2, 2007 | 04:15 PM
Warden's Avatar
Warden
Hello all, this is biscuit's old man, I tightened down the steering head nut and as I have always known, it is supposed to be pretty tight. When I cranked on it the rubber washer between the bearing and the nut folded and tore. Can anyone tell me how tight this nut is supposed to be. I can't find any specs on this.
I cranked it down and it fixed the wobble issue but I don't want to cause any other problems.
Thanks,
wmko1
Old Sep 4, 2007 | 01:10 AM
Warden's Avatar
Warden
bump
Old Sep 4, 2007 | 01:22 PM
Jip's Avatar
Jip
don't mean to be an ***, but are you sure your adjusting the right thing, the fall away is not adjusted by the nut on top, its under the nut and the rubber washer
Old Sep 4, 2007 | 03:27 PM
Warden's Avatar
Warden
Your not being an ***, thats what I was trying to find out. I have wrenched on my Jap cruisers but this is our first Harley's. They are quite different in build.
Thank you for your input.
