Rear tire replacement
Old Sep 25, 2008 | 09:36 AM
ozzy07840's Avatar
ozzy07840
Default Rear tire replacement
Has anyone ever replaced the rear wheel 200mm them selfs ??? is it worth the aggravation ?? do i need that belt tenchener tool to measure the slack ?? or do you think i should just take it to somebody ??? i got estimates of 70 bucks from independent shops and 125 from the stealer .... thanks
Old Sep 25, 2008 | 09:48 AM
jrjones's Avatar
jrjones
I have changed my rear tire a couple of times now. It is not that bad. Only thing I would suggest is make sure you have someone to help you. It will make pulling the rear axle easier and putting it back together as well. Also ensure you take the brake caliper off.
Old Sep 25, 2008 | 10:17 AM
anubisss's Avatar
anubisss
Take the wheel off an take it so an indy. That is what I always do. I have never needed a belt tensioner tool, but if you are new to rear wheel alignment you might want one. The stealers charge an hourly rate on the labor for tire replacement and it can get quite expensive. If you do this yourself just take your time. It is simple.
Old Sep 25, 2008 | 10:54 AM
softail04's Avatar
softail04
don't even mess with the rear wheel placement just remove the bottom belt guard and drop the wheel straight down.
put it back the same place as it was never loosen the adjustors.
also put the axel in from the left so next time you don't need to remove the pipes then take the wheel to somebody and get the tire changed my guy charges 20$ and does the balance also..
Old Sep 26, 2008 | 10:30 PM
tk353's Avatar
tk353
I get free labor when i buy from my dealer. $180 for the rear tire
billbrummett
Aug 8, 2018 05:13 AM
Tampa Fatboy
Dec 4, 2017 12:43 PM
AdrianVall
Apr 21, 2013 07:31 PM
Ryan V
Jul 13, 2012 07:31 AM
Hoblick
Jul 26, 2011 07:42 PM
