Lowering Advice
Old Oct 11, 2008 | 01:28 PM
JoeDirte's Avatar
JoeDirte
Default Lowering Advice
Hey guys im about too imbark on a father son project and could use some help, Son just got back from Afghanistan and were going to lower his 03 softail standard 2" front and back, using a ness kit, I have a book on my 97 heritage and am wondering if there is any differance between the two, book only goes up to 99, and if there are any tips, tricks, special tools that I may need too buy, borrow or steal too get the job done, the picture is me keeping his batteries charged while hes deployed...........GO 101st AIRBORNE
Old Oct 11, 2008 | 02:29 PM
story808's Avatar
story808
I don't think you'll need a book to do this... the shocks are different then yours though...
the rear anyway, if you look under there you'll see the difference between them... you'll have to remove the shocks the rear bolts i think they are 3/4 bolts and they are a bitch to break loose but don't give up... you'll need a bike jack... and when you get the shocks out you'll have too press them to change the stud on the end with the one from the lowering kit... or take them too a shop and have them press and RnR the stud... around here they charge around $50 for that... after thats done put the shocks back in and adjust the ht to where you like it the rear is done. My front is stock ht so you'll have to wait for someone else to chime in for that. Good Luck!
heres a pic of what the shocks look like after the bolt kit is on... just longer and a stiffer ride
Old Oct 11, 2008 | 02:54 PM
JoeDirte's Avatar
JoeDirte
Sounds pretty straight forward, is the picture of the shocks with the lowering studs installed? And did I read you right the lowering kit bolts are longer? And thanks for the reply
Old Oct 11, 2008 | 03:24 PM
DMJFatboy's Avatar
DMJFatboy
I lowered mine 2" while I was swapping out wheels. You will like it when your finished. I would suggest leaving the front alone unless your trying to lower it all the way around to fit a short person.
Old Oct 11, 2008 | 04:15 PM
story808's Avatar
story808
Yes the longer the shock the lower the bike gets.
Dan h
2014-2024 Touring Models
16
Oct 14, 2022 04:13 PM
GuitarAce
Sep 13, 2014 11:14 AM
fast99
May 14, 2013 08:23 PM
Rolo101
Mar 31, 2010 01:39 AM
mccadamsrh
Nov 20, 2008 02:57 PM
