Power for Lighted Plate Frame
Old 10-13-2008, 10:49 AM
doghair's Avatar
doghair
doghair is offline
Default Power for Lighted Plate Frame
Searching yielded no chewable info, I want to relocate the plate using the softbrake kit. I will need to tap some power for a lighted plate frame.
Question being where is the closest and least destructive place to get accessory power back there? I believe I'd need to bypass the tail light housing since I want the light to be steady, not toggling bright to dim when the brakes are applied.
Any assist is appreciated.
Old 10-13-2008, 05:47 PM
Dustmaker's Avatar
Dustmaker
Dustmaker is offline
Just need to tap into the tail light wires inside the tail light housing. Don't remember the colors of the wires off hand. I used the same one on my Heritage.
When you get it done, show us some pictures!
Old 10-13-2008, 06:46 PM
Dinger's Avatar
Dinger
Dinger is offline
There's a connector panel inside the tail lamp. You can test each connector socket with a testlight for the running lights and connect your license plate frame light wires. I have the same frame.
Get a Service Manual for instructions and the wiring diagram. It really helps.
Old 10-13-2008, 06:49 PM
jokr's Avatar
jokr
jokr is offline
Use the one that powers the license plate bulb when you take your tailight lens off you will clearly see the wire leading to the license plate bulb.....
Old 10-13-2008, 06:53 PM
jokr's Avatar
jokr
jokr is offline
the tombstone tailight does not have a connector panel........
Old 10-13-2008, 07:20 PM
doghair's Avatar
doghair
doghair is offline
I'll throw a fluke meter on it and take it from here. I was just curious what the survey said about using the the housing wires or running new.
I appreciate the replies. Gratitudus extremus.
Old 10-14-2008, 12:14 AM
05 HD Deluxe's Avatar
05 HD Deluxe
05 HD Deluxe is offline
Great tip Jocker! I am wanting relocate the billboard also.
Old 10-14-2008, 11:25 AM
bmr's Avatar
bmr
bmr is offline
I installed a pair of led lights on my axle mounted plate holder. First I soldered long enough wires to reach under the seat and shrink wrapped them and ran them on the back side of the swing arm. Then I stripped a small section off the end and wedged the wires in the connection harness running to the rear lights and secured it with electrical tape.
Old 10-14-2008, 04:05 PM
Slipstrm's Avatar
Slipstrm
Slipstrm is offline
I connected mine to the load side of the light and instrument fuse.
Meist21
07-05-2018 05:38 AM
Sandbox
03-27-2013 08:28 PM
Toy_Jon
05-16-2010 09:42 PM
spence222
04-15-2008 08:19 PM
mikeurig
12-22-2006 12:23 AM
Quick Reply: Power for Lighted Plate Frame
