Why do I need a PC III?
Old Oct 22, 2008 | 04:53 PM
newdep332's Avatar
newdep332
Default Why do I need a PC III?
I have a 09 Heritage with Screamin Eagle stage 1 A/C and download, I also have Rush 1.75 slip ons. The bike seems to be running great to me, however; I'm new to this. I have been told to get a PC III from Fuelmoto, my question is what will it do for me if I already have the HD download?
Also if I get one set up for the 1.75 baffles and then switch to 2.00 will I need another map?
Thanks in advance
Old Oct 22, 2008 | 09:30 PM
Bowtieman31's Avatar
Bowtieman31
The Stage I download is good for what you have. If you do any engine mods, you will need to upgrade your bike with a PCIII or SERT or whatever. The download you have still runs towards the lean side of the mixture curve but it is acceptable for you current mods.
Bottom line is you don't need one now, but may later.
Old Oct 22, 2008 | 09:48 PM
SuperUnknown's Avatar
SuperUnknown
The PCIII will give you a better range of tunability...I recently changed pipes (from V&H to Rineharts) and was glad I had the PCIII over the HD download.
Old Oct 22, 2008 | 10:07 PM
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
Here is some basic info on tuning http://fuelmotousa.com/faq.htm
You can also contact us with any questions regarding EFI tuning
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Old Oct 23, 2008 | 12:03 AM
wallyn's Avatar
wallyn
FYI on the 2007 - 2009 bikes.
They will adjust to changes made to the air intake and exhaust systems. They will however adjust to the EPA mandated 14.5 AFR. As many know this will not give the best power curve and will run hot in most areas of the country.
If you are looking for optimum power and performance and not cook your thighs then you many be in the market for a fuel management system.
Old Oct 23, 2008 | 12:22 AM
azfathog17's Avatar
azfathog17
Just make sure it is not pinging with your set up. You get no ***** with the HD download. It is sort of a Kmart canned SERT or SEST. If it pings you will need the ***** from a SEST or PCIII to adjust the timing or fuel, or for the dyno.
The download worked well for my friend's Electra Std.
paco ritter
Mar 19, 2008 03:43 PM
classicglide
Dec 20, 2007 08:00 PM
deerhunter
Aug 8, 2007 08:18 AM
Parrothead
Jun 21, 2007 01:07 PM
Manish_Hawg
Jun 1, 2007 11:20 PM
