Progressive Suspension on a Softtail
Old Oct 23, 2008 | 07:33 PM
bonzer's Avatar
bonzer
Default Progressive Suspension on a Softtail
Is anybody out there running Progressive 422's on their Softtail? I bought a set for my Crossbones and am having a heck of a time with the rear mount bolts to get the stock ones off. Don't want to force them too much. Anybody know the trick for removing them? Thanks
Old Oct 23, 2008 | 09:20 PM
crazybastid83's Avatar
crazybastid83
Use a torque adapter.
Old Oct 23, 2008 | 09:25 PM
crazybastid83
http://buy1.snapon.com/catalog/item....store&tool=all
Or maybe cut down a 3/4 wrench.
Old Oct 23, 2008 | 09:47 PM
rkeith01's Avatar
rkeith01
yeah get the friggin hercules that installed them to loosen them :-) .....they're a friggin bitch to remove..what I did was take the 3/4 wrench and whack it with a rubber mallet a few times and they'll eventually loosen up..
Old Oct 23, 2008 | 09:49 PM
anubisss's Avatar
anubisss
Stand on a long wrench with all your weight.
Old Oct 23, 2008 | 09:56 PM
bonzer's Avatar
bonzer
Thanks guys, I had alot of a$$ on it. Just wanted to make sure I wasn't missing something before I got mean with it.
Old Oct 23, 2008 | 11:32 PM
imboden's Avatar
imboden
+1 amigo. I used a rubber mallet on my wrench to bust it loose. they're on with red loctite, so be sure and put that stuff back on em when you re-install.
Old Oct 24, 2008 | 01:23 AM
Lowbro's Avatar
Lowbro
Bonzer, your going to like those 422's. made a night & day differance on my scoot.I slammed mine 1.5 . I second that idea with the rubber mallet.
Old Oct 24, 2008 | 08:56 AM
tmitchellof PG's Avatar
tmitchellof PG
Did you use a heat gun, to release the loctite grip, right before you tried to loosen them?
Tom
Old Oct 24, 2008 | 10:16 PM
bonzer's Avatar
bonzer
Used a little heat and a big hammer and got them loose. Just got done installing the new ones. Tried to keep the same ride height but I'm quite a bit higher. Guess I'll lower them tomorrow. Set them a little too stiff (used to the stockers) I'll get 'em dialed in. One thing I noticed is that when I adjusted them the ride height adjustment moved too. I had to use a 3/4" wrench for a back up. Anyone else run into this?
