1157 signal bulb VS LED replacement problem.
After that every few months I would notice one of my front signals would blow out. Usually the running light part, Turn signal would still work. I wondered since the rear was LED maybe still too much draw on the bulbs up front burning them out. Decided to get LED 1157 style replacement bulbs for front earlier this year ,all worked well.
NOW the fun part. I see the other day one bulb up front out. (Running light part- Signal works fine) Pull off the covers fiddle with bulb, comes back on. I find out it's that bulb. Just to make sure I switch sides with it, still that bulb not the housing. Something inside not working or loose.
I order two similar type replacements from local shop. See pic below, Old bad bulb is on left. Ordered new style on right because it has that collar to grab when you put it in and you have to twist it into the housing to lock it in. I think the problem with old one is the plastic housing cracked when I locked it in the first time breaking some connection inside.
Put NEW bulbs in, switch on ignition and they go on- then blow 15 amp instrument fuse under seat. After fooling around (and using up spare fuses) I throw in regular 1157 bulbs all is then well.
So that's where I'm stuck, why new bulbs blow fuses and old ones and regular incandescent bulbs don't. Also other difference between old and new bulbs is old has 20 LEDS , new bulb has 11. Is there another load EQ needed for the front? I thought the one I put into the harness was the only place to add one, covering front and rear.
Thanks
Rob
2005 nightrain
Carbed.
Stage I
Roland Sands Design VENTURI AIR CLEANER
Arlen Ness forward control extension kit.
V&H Straight shots
Radiant Side mount license plate light with LED cats-eye (discontinued)
Kuryakyn LED side rear marker/ turn lights
HD Diamond Back solo seat
Rob
Rob
had a rapid flash problem with mine. what is the plug and play load equalizer you used. i ended up switching back to regular 1157's cause i couldn't find a load equalizer. i like the leds but didn't like the rapid flash. thanks
As far as I can tell this plugs into the entire system and is supposed to do front and rear.
Rob
