Fog lights?
Old Oct 29, 2008 | 12:31 AM
jtmurph00's Avatar
jtmurph00
Default Fog lights?
Ok, Im damn near completely blind at night (seriously, not joking) and adding a set of fog/driving lights to my truck helped alot. So, I thought about it and why the hell not add a set to the bike also. I know Harley makes a set for mounting on a highway bar but would a regular set automotive fog lights work? I mean could I install a set without it messing up the voltage, same deal as having to put on a voltage regulator if you put on LED turn signals? Id like to wire them off of the brights switch, possible?
Old Oct 29, 2008 | 02:20 AM
qwispichkn's Avatar
qwispichkn
Default lights
You too huh...Find my high beams lacking also, looking to put a set of passing lamps on.
I've seen them mounted on the front frame also.
Old Oct 29, 2008 | 02:36 AM
HawgMan_renamed's Avatar
HawgMan_renamed
I have the HD fog lights on my Heritage and love'um. A big help for the blind..lol
Old Oct 29, 2008 | 06:00 AM
oldgeezer's Avatar
oldgeezer
Same here but I've decided to not ride at night unless absolutely necessary, which is almost never.
Old Oct 29, 2008 | 07:28 AM
chidiver's Avatar
chidiver
I added the passing lamps to my 08 Fat Boy and run them all the time, even during the day. They are aimed on the low side. I feel it helps me be seen a little better in Chicago traffic. They do help quite a bit at night, though the Harley way of doing things has them wired to the low beams. It may not be legal in your state to have them tied to the high beams.
Old Oct 29, 2008 | 09:34 AM
aviator's Avatar
aviator
IF you have to ride at night - a set of passing lamps or fog lights, mounted low should help. I'm with the oldgeezer - I'd rather not ride at night.... must be these old eyes
Old Oct 29, 2008 | 10:27 AM
anubisss's Avatar
anubisss
Also get a brighter headlight. Sylvania silver star works great, but seems to burn out quickly. Model #H4ST was what I used.
Old Oct 29, 2008 | 11:18 AM
ngoti8tor's Avatar
ngoti8tor
Why not wire them to your low beam, then you can ride with them on all the time?
It's illegal to have them tied to the high beam in most places. There's a way to make them stay on whether you have high or low beam on though.
Old Oct 29, 2008 | 05:57 PM
Buddha4's Avatar
Buddha4
I set up some PIAAmodel 910 running lights they have no problem outshinning the headlights. once you figure what style you want then you can figure out how they will be mounted. You will have no problem with the charging system supporting lights (mine are 85watts) and I can still run heated gear. I'm a big fan of function over asthetics when it comes to safety.
Old Oct 29, 2008 | 07:05 PM
nickm's Avatar
nickm
does any one have a clearer picture of the attachment above?
Thanks
