Pulley question
Old Apr 9, 2009 | 09:02 PM
zss42002's Avatar
zss42002
the wider belt will not fit they did a 20mm pulley 7/8" belt because of tire and swing arm clearance. I found a 20mm pulley 66 tooth and a 70 tooth. stock is 66 what would i gain by getting the 70??
Old Apr 9, 2009 | 09:07 PM
Whoad00d's Avatar
Whoad00d
+1 on the the answer to the 70 vs. the 66.
Russ
Old Apr 11, 2009 | 02:49 AM
gabadoo's Avatar
gabadoo
66T is for 6 speed bikes. 70T is for 5 speed bikes. You will need a 20mm pulley, 70T and a 7/8" belt with a 18x5.5 wheel. Stock swing arm will work along with caliper. Fender struts and fender and most rear accesories will have to be changed. I only kept the swingarm if its any indication of what to come. Of course i swapped out factory for chrome alternatives but you will change out quite a few parts....
Drill4gas
EVO
Apr 24, 2015 06:15 AM
stmcmann
Feb 1, 2013 09:31 PM
Camaro67
Jul 7, 2012 11:35 AM
Road King Kid
May 7, 2010 05:21 AM
PTS
Jul 2, 2006 01:01 AM
