Help Help with Rocker c
Old Dec 9, 2008 | 03:56 PM
scs1inc's Avatar
scs1inc
Default Help Help with Rocker c
Can any one tell me how to change the left read tail light...on my Rocker c the wireing look's like a bitc-- can some help me out with this Thanks Scs1
Old Dec 11, 2008 | 01:11 PM
scs1inc's Avatar
scs1inc
no one no how to replace read tail light on rocker c
Old Dec 11, 2008 | 04:34 PM
jonnynh's Avatar
jonnynh
Stage III
Default FXCW/C Rear turn signal
Rear turn signal: FXCW/C
  • Unplug 12 pin connector to the right of the battery.
  • Remove rear fender 4 bolts two on top and two under.
  • Disconnect pins for the light you need to replace. MOLEX CONNECTOR.
    PIN
    Color
    Function
    BE
    Right running
    R/Y
    Right stop
    BN
    Right turn
    BK
    Right ground
    O/W
    Domestic tail lamp
    BK
    Tail lamp ground
    BE
    Left running
    R/Y
    Left stop
    V
    Left turn
    BK
    Left ground
    11
    R/Y
    HDI stop
    O/W
    HDI tail lamp
  • Remove fastener securing lamp assembly to fender.
    NOTE:Before removing the electrical wires from fender, attach an electrical fish tape or long thin wire to the ends of the electrical wires to aid during installation.
  • Carefully remove lamp and wires from fender.
  • Route wires of new lamp through fender. Make sure the new wires are properly positioned in the retaining clips.
  • Attach new wires to 12 pin connector.
  • Attach turn/running/stop lamp to fender. Tighten fastener to 10-12 ft-lbs.
  • Check wiring installation for proper routing and make sure there is no excess slack in the wires. Also check the retaining clips and wire harness channel for looseness and damage.
  • Install rear fender start upper and lower bolts by finger than; torque upper mounting bolts to 30-35 ft-lbs. Lower bolts to 28-32 ft-lbs. *Loosen upper bolts and re-torque upper bolts to 48-52 ft-lbs.
Old Dec 11, 2008 | 07:18 PM
5speedblu's Avatar
5speedblu
sponds like a pain iin the ****, I miss my 77 the wiring was easy.
Wait the bike sucked. I changed my mind.
apblingAEW
Jun 13, 2015 07:19 PM
STREET BOB JOE
Feb 12, 2014 11:06 PM
Reaper_ggy
Oct 31, 2011 08:55 PM
doggin_it
May 8, 2011 11:38 PM
bikermike2
Feb 4, 2009 03:39 PM
