Lost tailight wires protector
Old Jun 18, 2011 | 11:46 PM
Reaper_ggy's Avatar
Reaper_ggy
Default Lost tailight wires protector
So I dont know why I decided to look into my rear fender and realised that all my wires where naked, I've putted some plastic wires protectors and repassed the wires in the dents made for them, secured everything with ductape ... temporarly.
So What should I put there ?
Definitively not buying another cap , if they sell them anyway.
Old Jun 19, 2011 | 02:44 AM
fxdx-fly-by's Avatar
fxdx-fly-by
3/8 pvc cut to length and put into the clips that hold the wires then a little jb weld worked well for me, but i cut off the plugs and re wired for new tail tag and blinker lights. i had bottomed out the bike before and destroyed the whole loom of wires.
Old Jun 19, 2011 | 04:16 AM
HemiOrange's Avatar
HemiOrange
Not sure if you are talking about the entire wire run under the fender or just in the tail light area. HD makes a decent stick on "conduit" thing that came on my bike that runs near top centerline from front to rear. My WCC Jesse James fender came with two 3/8" metal tubes on right and left top side for running wires.
You could clean up the under fender, slit some PVC or tygon tube or use shrink tube to run the run the wires through and use hot glue, JB, existing tabs or whatever seems best.
Removing and replacing that rear fender isn't as difficult as it might look. Just slide some dowels or 1/4 to 5/6" bolts through the strut holes to aid you in removal and realignment of the fender. The entire rear harness unplugs quickly from under the seat. A lathe or shim placed crosswise between the tire and fender also help me, but if you don't have the clearance, maybe a 2x4 on top of the tire will help to keep the fender in place while removing and reinstalling. It's a simple job and way easier than doing this work with the fender still mounted on the bike.
Old Jun 19, 2011 | 08:41 AM
Reaper_ggy's Avatar
Reaper_ggy
Didnt tought of that, you got pictures ?
Old Jun 20, 2011 | 06:12 PM
JRK5892's Avatar
JRK5892
i ran mine long my inner frame rails though shrink wrap works awesome!
Old Oct 31, 2011 | 09:57 AM
Hitman1318's Avatar
Hitman1318
Anyone knows the part number for this tail light wires protector? Trying to search for one at ebay but couldn't get any. Thanks!
Old Oct 31, 2011 | 08:55 PM
HemiOrange's Avatar
HemiOrange
Try searching Ronnie's HD. My replacement rear harness came with the rubber factory stick-on conduit. It might be available separately, though as part #70540-02 for about $8 plus $12 S&H from Ronnie's.
willy215
Jun 21, 2015 12:22 PM
apblingAEW
Jun 13, 2015 07:19 PM
scot1968x
Jul 7, 2009 08:05 PM
hottrocker
Jan 16, 2009 03:08 PM
PLOWBOY517
Jan 10, 2007 10:41 PM
