Throttle hesitation
Old Dec 10, 2008 | 11:20 AM
wgotto's Avatar
wgotto
Stage IV
Default Throttle hesitation
Have owned my '02 Heritage (5200 miles, carb.) for about 2 months and have had it to the dealer several times for a hesitation that is constant when I slowly open the throttle at low rpm's with the enrichener fully closed, even when the bike is fully warmed up (does not happen when the enrichener is more than 1/4 open). Dealer says there are no problems with it after several rides by their techs. I can only compare it to my XL, but I can't believe this is normal. Any help?
Old Dec 10, 2008 | 12:16 PM
Mr. Lucky's Avatar
Mr. Lucky
The enrichener is a choke (i.e., it lets less air in across the board, thus making the mixture richer). If it only happens off idle and not when the enrichener is part way out, go up a size on the idle jet. This will accomplish the same thing, without making you run too rich through the rest of the rpm range.
Old Dec 11, 2008 | 10:52 PM
tk353's Avatar
tk353
maybe the accelerator pump is clogged. easy to check. just remove the air filter and look for a squirt. if it is there then maybe a vacuum leak.
Old Dec 12, 2008 | 05:34 AM
Blk and Chrome's Avatar
Blk and Chrome
I would find another dealer or indy to get that fixed. either its dirty or the jets are too small.too lean, a friend had the same issue and a indy fixed it for him
gregwg
EVO
13
May 31, 2018 04:51 PM
Vladious
May 30, 2013 08:24 AM
lkr0
Feb 5, 2013 12:34 PM
valkal
Exhaust System Topics
Aug 18, 2008 09:34 AM
Scott Safe
Feb 3, 2006 02:43 PM
