2008 fatboy grips removal
Old Dec 21, 2008 | 07:30 PM
plopper's Avatar
plopper
Default 2008 fatboy grips removal
any helpful hint on how to take apart the throttle housing,im replacing the grips, left side was real simple but the right side looks a litttle tricky, anyway thanks ahead of time
Old Dec 21, 2008 | 07:48 PM
ngoti8tor's Avatar
ngoti8tor
If it's just the grip that you need removed, the original grips are glued in place and have to be cut off.
Old Dec 22, 2008 | 06:01 AM
WAhog's Avatar
WAhog
Default changing grips
A few things...and I'm not mechanical! There is a tiny little switch on the brake leaver side assembly that can be easily broken if you arent careful - cant remember how to avoid this other than putting a wedge in where the lever hinges.
Other than that its pretty simple once you've cut the originals off. You'll probably need some WD40 to remove the remnant glue as the new grips should be glue free.
I am a novice and I changed the grips a couple of times but I would suggest that you have someone with you to assist if you can, even if just to hold the assembly as you undo. Just follow the instructions that come with the new grips.
Final thing, make sure you 'loctite' the screws in place when you are done as they work lose otherwise - I had to get my dealer to replace mine that had gone awol.
Cheers
Old Dec 22, 2008 | 06:14 AM
hogdiver96's Avatar
hogdiver96
Im not mechanically minded at all but this is easy but tricky ...undo housing on throttle side , pull housing apart...(take a digital photo-graph just in case.
two cables under there with brass LOOSE nipples on , twist throttle one way , remove cable and nipple careful not to drop it..thtwist throttle other way and do the same ...basic stuff and you will figure it out but if you have fat stubby fingers you may be stuffed !
Old Dec 22, 2008 | 07:17 AM
tk353's Avatar
tk353
I used vice grip covered in cloth so as not to hurt the cable and used it to keep the throtle from closong so i could work with the cable. It was so easy and the left side i did not open the housing. i cut the grip aoround the housing and that kept the old grip water seal.
Old Dec 22, 2008 | 07:42 AM
hellfish's Avatar
hellfish
On Kuryakyn's site they have a video how to remove 'em ...look towards bottom.
http://www.kuryakyn.com/index.cfm/go...scID/9/IMID/33
Old Dec 22, 2008 | 09:35 AM
anubisss's Avatar
anubisss
Just watch out for the brass ferrules as they fall off real easy and are a bitch to find on the ground. They are on the end of the throttle and idle cable. As someone else said have a few extra available in case you drop them. Makes it much easier...
Old Dec 22, 2008 | 09:49 AM
GymRat523's Avatar
GymRat523
He is correct, even though I knew this I dropped the stupid thing anyway, I was in my garage and got lucky and found it.
Old Dec 22, 2008 | 09:55 AM
aggro_jo's Avatar
aggro_jo
Originally Posted by tk353
...and the left side i did not open the housing. i cut the grip aoround the housing and that kept the old grip water seal.
excellent idea!
hogdiver96
Mar 27, 2013 12:18 PM
Dually_TG
General Topics/Tech Tips
Aug 16, 2012 01:16 PM
mike_oh
Apr 15, 2012 10:11 PM
AdrianVall
Mar 7, 2009 10:22 PM
wayne72472
Jan 19, 2009 12:00 AM
