new grips!!
Old Jan 18, 2009 | 04:16 PM
wayne72472's Avatar
wayne72472
Default new grips!!
what is the easy way of taking the old grips off!
Old Jan 18, 2009 | 04:33 PM
jmpancoast's Avatar
jmpancoast
If you are replacing the OEM soft rubber grips, you can take a razor knife and slit the left one, then pull it off. The right one will come off with the throttle barrel. If your new grips come with a new throttle barrel, you are good to go. If not, you will need to cut the right side and separate from the throttle barrel. Of you have a syringe, you may be able to inject solvent under each grip and work them off as the adhesive loosens. Be careful with solvents around finished surfaces.
Old Jan 18, 2009 | 04:34 PM
Royce's Avatar
Royce
Wayne, some folks will tell you to use a razor blade to take them off which will work, but obviously ruins them if you ever want to use them again. The easiest way is to remove the clutch assembly (all of 4 screws) and then take a long, fairly slender screwdriver and work it under the grip. Once you've created a little gap, spray some WD40 in the gap and work the screwdriver around to squirt some more WD40 in there. You should be able to grap the grip and twist using the screwdriver to help loosen the grip. It'll pop off fairly easily and you still have a good grip. Clean the handlebar up with some warm, soapy water and put your new grip on.
Old Jan 18, 2009 | 04:43 PM
bberck's Avatar
bberck
I was able to twist my left grip by hand after removing the housing and break the glue free. Right one will slide off after removing the housing and taking the ferrules out.
Old Jan 18, 2009 | 04:58 PM
devils haircut's Avatar
devils haircut
Use a hair dryer to heat up the grip and glue first... then twist it off. Don't lie, I know some of you trashy mullet bikers have hair dryers!!!
Old Jan 19, 2009 | 12:00 AM
rayfinseats's Avatar
rayfinseats
I heard when installing new grips spray the handle bar end with Aquanet hair spray. WHen it dries it's sticky but you can get them off next time. I have been using grip glue for bicycles. (cheap and easy to find.) Also an option. If you don't want the old grip just slice it down the middle.
straps
Mar 15, 2011 07:03 PM
jmorris42
Feb 21, 2011 10:40 AM
cannedham1
Mar 30, 2010 07:55 AM
Tri glide 10
Jan 23, 2010 09:02 AM
Kansasjase
Oct 30, 2009 07:05 AM
