Chrome Pipe Question
Old Dec 22, 2008 | 10:35 PM
Beerninja's Avatar
Beerninja
Default Chrome Pipe Question
Ok here is the deal, I have only had my very first bike for one week today ('02 Fatboy) and I really love the sound of the pipes she has on her, but I am not a big fan of all the chrome so I am looking to darken things up a little, is there a way to keep the pipes but blacken them out? I have V&H Long Shots on here right now, and really don't want to change them if possible.
THanks in advance
Old Dec 22, 2008 | 10:46 PM
Kevinc's Avatar
Kevinc
You can rap them with dark heat tape for the rat bike look. (I like the look) Or I've heard of guys painting them with black barbecue grill paint. I have never seen this done, but ig you hate the look what have you got to loose. You could put some bbq paint under the heat shield where it won't show and drive it around for a few weeks and see how it looks. If you like it paint he heat shields. If you don't like how it looks you could always go the heat tape rout.
Good luck. These low cost "real" custom modification (verses just buying skull stuff) can be very rewarding.
Old Dec 23, 2008 | 12:20 AM
xxxflhrci's Avatar
xxxflhrci
On the 'el cheap, you can sand them and paint them with high heat rattle can paint. I have a set of drags that I did that way. They held up fine. Or, you can spend a few bucks and get them powdercoated.
Old Dec 23, 2008 | 12:29 AM
57RebelRocker's Avatar
57RebelRocker
seen it done a few times with a good flat rattle can paint and looks and holds up great...or opt for the more expensive way powder coat 'em
Old Dec 23, 2008 | 12:40 AM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
I would go the VHT paint route first and if it looked OK, get them ceramic coated in black.
I'm not much of a fan of powdercoating pipes, a little too much heat and they can turn gray or flake off. Ceramic coatings are a bit more expensive, but where heat is conserned the coating is virtually indestructable. It also helps to keep the heat inside the pipes where it belongs so you don't feel as much outside.
Old Dec 23, 2008 | 03:38 AM
sonar_chris's Avatar
sonar_chris
Take the heat shields off and have them ceramic coated black. It will last a lot longer than rattle can paint, you wont have to change or even remove your pipes and you will get the dark look your looking for.
Old Dec 23, 2008 | 06:53 PM
Beerninja's Avatar
Beerninja
Sweet thank you all for the replys, around about how much does it cost for the ceramic job?
Old Dec 23, 2008 | 09:07 PM
sonar_chris
Anywhere from $15-25 a foot depending on what you want and who does it.
Old Dec 23, 2008 | 10:35 PM
When I was thinking of putting on slipon mufflers I got a quote for about $90 to do the stock pipes (inside and out) in black.
dhamilton20
Sep 18, 2015 09:33 AM
apetterez
Feb 9, 2015 11:09 AM
fatguy-littlebike
Jan 23, 2015 01:50 PM
Andra2000
Oct 9, 2012 09:05 PM
ultravista
Exhaust System Topics
Feb 11, 2006 12:58 AM
