Need Help Quickly She is Not Rideable...
Tnicean
Between the shocks at the forward end is the transmission drain plug, which is also takes a 5/8" socket. There are 'O' rings that go on each of these drain plugs. Put 3 quarts of oil in the oil tank, then take it for a ride until the engine is warmed up. Check your oil level, with the engine warm, within a few minutes after you shut it off. Top off as needed
My 2005 requires the bike to be on the jiffy stand to check the oil level. I think your year the bike should be straight up, but I'm just guessing. You are better off having a little less oil, then too much oil in the tank.
I use a strap wrench to remove the oil filter. Put a piece of cardboard or aluminum foil under the filter, so oil that drips while you are removing it doesn't puddle on your engine.
Your transmission fluid level needs to be checked, when the bike is standing straight up.
Good luck.
TMitchell thanks a million for your post. I was about to have someone tig weld a nut on that plug and remove it. I feel really stupid as I have actually changed my oil before. I just forgot the plug was built into the frame. I changed the transmission fluid and primary too. While I am here, what oil, transmission, primary fluid do you use?
