Replacing ALL Torx Screws?
Old Dec 28, 2008 | 07:48 AM
PPBART's Avatar
PPBART
Default Replacing ALL Torx Screws?
I've seen several recommendations to "throw away the crappy Torx screws" and replance them all with stainess steel Allen (hex) head screws.
Is there a compiled reference list somewhere that lists all the Torx screw sizes used on my FLSTN, or will I have to just do this one screw at a time? I've like to just get a whole set of replacements at once.
Old Dec 28, 2008 | 08:17 AM
jimmers1817's Avatar
jimmers1817
These forum sponsors may have what you're looking for. I recall there are some problems you can run into with stainless screws interacting with aluminum. I think it calls for using anti-seize with them.
http://www.shopv-twincycles.com/shop...catalogId=1137
If not these folks should:
http://www.gardner-westcott.com/motor_pdf.html
Old Dec 28, 2008 | 08:27 AM
fliphd's Avatar
fliphd
From: West central Illinois in the Mississippi river bottoms
Thats weird, I myself like the torx head screws way better than allen head. Jost go to sears and buy a good set of torx head bits and you'll have no problems at least I have'nt. I've actually had more problems out of allen headed screws. Go on Ebay they sell complete replacement screw and bolt sets for all bikes. Stainless and chrome I personally go with the stainless torx heads.
Old Dec 28, 2008 | 09:27 AM
PPBART's Avatar
PPBART
Thanks for the links. You're right about the potential problems with SS in AL. I understand that SS screws going into aluminum are sometimes cadmium plated to avoid galling and galvanic corrosion; however, cadmium plating isn't very visually attractive.
Old Dec 28, 2008 | 11:01 AM
57RebelRocker's Avatar
57RebelRocker
I put acorn nuts on mine...looks alot better
Old Dec 28, 2008 | 05:34 PM
ronyd's Avatar
ronyd
I replaced many of them with 12 point. Real nice looking... Look at
http://www.gardner-westcott.com/motorcycle_bolts.htm. I believe local HD has them also...
Old Dec 28, 2008 | 05:40 PM
tmitchellof PG's Avatar
tmitchellof PG
You should be thankful that Harleys are not like old Triumphs. They used Phillip heads on everything. I replaced all of them with socket head cap screws, so I could use Allen wrenches.
I don't have any complaints with the Torx.
Tom
Old Dec 28, 2008 | 06:09 PM
Dustmaker's Avatar
Dustmaker
I agree with some of the larger torx, but the smaller screws are not to bad. As suggested, get yourself a good set of bits and you will be ok.
Old Dec 28, 2008 | 06:35 PM
P'colaHarley-17RGS's Avatar
P'colaHarley-17RGS
I just bought a good set or torx head bits from Home Depot... 11 pc set for $15
Tomhummer... acorn nuts???
Old Oct 22, 2020 | 08:52 PM
DaveTV's Avatar
DaveTV
5th Gear
I tried looking up the threads to get Allen bolts to replace the torx bolts. Does anyone know the torx size for the brackets connecting the footboards to the Fatboy Lo? I have tried a T-45 but it feels a bit loose.....just a bit. :-)
