help with TFI
Old Apr 12, 2006 | 10:36 PM
broke joker's Avatar
broke joker
Default help with TFI
I have a 05 springer classic with the stage 1 kit and i just bought a TFI because the download the dealer does is junk. Pulled the plugs out and they are white, still f***ing lean. Does anybody know how to tune the TFI, as for as some good setting for the thing.
Old Apr 13, 2006 | 02:43 AM
SoftailBrian's Avatar
SoftailBrian
Default RE: help with TFI
I've got the TFI on my 06' Standard. I just did what the insturctions say. Bring the motor up to operating temps, bring idle to about 2000 RPMs, then adjust the rest per instruction settings. If you don't have the instructions let me know what mads you have and I will look at my instructions and let you know what it says. Good luck!
Old Apr 13, 2006 | 05:42 AM
darkside's Avatar
darkside
The TFI will come with some base line starting points.Start with these and ride it to see where your at.I found info on here that the settings they give you are a little rich.I backed mine off almost one full position on each setting to get it right.If it says 4 try 3 or so.Only on the 3 pots that control fuel not the third one wich is the RPM in wich the main jet comes in. Hope this helps if not PM me and i will try and help some more.
thruster
General Topics/Tech Tips
Jan 9, 2008 10:49 PM
zzmellio
Apr 26, 2006 12:03 AM
txspringer
Apr 24, 2006 10:16 AM
Dsrt
Jan 25, 2006 01:04 PM
Streetrunner
Jan 10, 2006 03:42 PM
