primary
Old Jan 9, 2009 | 01:58 PM
dan l's Avatar
dan l
Originally Posted by anubisss
That horn rules. I'll bet it's loud as can be...
yeah its loud i love the look of your bkie thats what im goin for
Old Jan 9, 2009 | 03:08 PM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
Hope you have a fat wallet, duplicating a sweet ride like his is gonna make your wallet cry for mercy.
Old Jan 9, 2009 | 10:02 PM
dan l's Avatar
dan l
Originally Posted by rsavage
If you pull the clutch inspection cover (the round cover) you won't need to drain the quart of oil that is in the primary chaincase. However, you aren't going to see much. See how loose the chain is. If it is too loose there might be a problem with your chain tensioner. If it's an EVO you won't have an auto tensioner. Looks like you have an chain tensioner door (small plate held on by 4 screws on the chaincase cover to the left towards the front of the bike). You can also look in there, feel the chain for tautness without losing oil.If it is loose, you can adjust it through this window. If you pull the whole primary chaincase cover, you'll have to drain the primary. Good luck - nice looking bike. I have no idea the noise might be, but that's a good place to start if it sounds like it is coming from the primary area. Could be the compensating sprocket loosened up? Sometimes you can sort of isolate where a noise is coming from by using a stethascope or putting a screwdriver against your ear ( non pointy end) and placing the other end against various places on the motor as it is running. If I were you, I would definitely determine what is making noise before running for more than evaluation.
hey savage i took a look in side the chain tesioner and felt the chain it had some play in it.i tried to adjust it but i dont know if im doin right.But i do know that the block with the adjuster nut that bites into the teeth,when i move it around,it makes that sound ,so i tried to pry up the block higher and tightened it back up....is that right....... thanks again bro its nice people like you that i need in my life to help me out
Old Jan 9, 2009 | 10:05 PM
dan l's Avatar
dan l
Originally Posted by tomhummer
looks nice welcome to the forum
thank you bro
Old Jan 10, 2009 | 04:51 AM
rsavage's Avatar
rsavage
Dan1
Yes, you loosen the center bolt nut and move the shoe assembly up to take out slack. You should have 5/8" to 7/8" deflection up or down when cold, 3/8" TO 5/8" if hot. Don't over tighten the chain so there is no deflection.
Old Jan 10, 2009 | 11:02 AM
pococj's Avatar
pococj
If the tensioner adjustment doesn't get rid of the noise, you might have a bad compensating sprocket.
Old Jan 10, 2009 | 05:00 PM
dan l's Avatar
dan l
Dan1
thank you so much
Old Jan 10, 2009 | 05:02 PM
dan l's Avatar
dan l
thank you much
Old Jan 12, 2009 | 05:33 PM
dan l's Avatar
dan l
Default shifter
Dan1
hey savage thanks for the info.i have another question for you.when im in first gear and i run up the rpm's ,switching into second just doesnt want to happen.i have to do it twice.it seems as if i wined out first it dont want to go.but if i take it real easy in first it will switch with no problem...any ideas....also neutral is very hard to find.you have to hit that shifter up and down ever so slightly to finally get it ..is this inside the trans and is it something i could do.
Jr Canaguier
Aug 22, 2015 08:25 AM
blackbaxterbuddy
Panhead
Jan 16, 2013 05:34 PM
runnin2fire
May 5, 2010 03:55 PM
witter
Mar 19, 2010 08:32 PM
river rat
Nov 23, 2007 07:43 PM
