Switch housing insides
Old Jan 16, 2009 | 07:18 PM
J_DORSETT's Avatar
J_DORSETT
Default Switch housing insides
Does anybody have a picture of how the inside of the switch housing? my brake light switch is staying engage because i dont think i put it back together right when i put chrome switch housings on my switches. any help would be greatly apreciated.
Thanks,
Justin Dorsett
Old Jan 16, 2009 | 07:53 PM
rbabos's Avatar
rbabos
You didn't break the little round tit off the end of the plunger did you? The other problem is there is a bent brass flat spring that needs to go at the back of the switch to push it forward. Without this it will likely not shut off. Sorry, no picks.
Ron
Old Jan 16, 2009 | 08:38 PM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
I think rbabos has it down. Your going to need to disassembe it and recheck your work.
If you have a service manual it will show the parts breakdown and the assembly process so you can make sure you get back together right.
Old Jan 16, 2009 | 08:47 PM
BLKnCHRME09Deluxe's Avatar
BLKnCHRME09Deluxe
....recheck and align everything
Old Jan 16, 2009 | 09:01 PM
J_DORSETT's Avatar
J_DORSETT
ok that spring is the problem. if fell out when i had it apart and was not sure how it went back in and just put it where it looked like it might go. that makes sense. thank you
Old Jan 16, 2009 | 11:16 PM
drkenigma1's Avatar
drkenigma1
The spring is the easy part. Just make sure the button is seate correctly and then the little brass "spring" slides in. Use a small screwdriver to push it into place.
soulpatch
May 27, 2019 01:14 AM
Thumper26
Sep 13, 2016 08:42 AM
Jesse96Heritage
Electrical/Lighting/Alarm
Apr 8, 2016 06:41 PM
jinxy
Sep 6, 2007 03:12 PM
hbski
Dec 13, 2006 08:21 PM
