This is on an '09 Deluxe. I have the HD shock spanner, read the owner's manual and service manual. Both say to loosen the jam nut, and then rotate the adjuster plates -- toward the jam nut to increase preload, away to decrease.
I turned them for at least 20 full rotations without coming to an end, and then realized not only was the entire shock body turning, but the shaft was, too. The shaft should remain stationary, right? Otherwise, how am I going to see a change in the number of threads showing? Am I supposed to grab the shaft (or the shock body) somewhere while I'm turning the adjuster plates?
I'm sure I'm missing something obvious. Anyone have any ideas?
I adjust mine quite a bit and haven't had that problem. Your Deluxe has the low profile shocks that lowers the rear about an inch. I have the same shocks on my SE Fat Boy, since it came lowered in the rear also.
I loosen the retention nut and spin it back out of the way. Then use the spanner wrench to turn the shock body until it is set where I want it. Could it be that you are at the end of the travel for the shock body and by continuing to turn it the shaft turns also?
Did you try turning either shock the other direction? They come from HD at the fully soft setting, with approximately 4 threads showing.
I turned both shocks all the way, in the same direction, to get a starting point. Then I used a brush to paint a white stripe, on the bottom of each shock, running forward to aft. This makes it easier to count how many turns so you can keep the shocks equally set. Whenever I turn the shocks all the way to soft or firm, I turn the shocks back just a little, so they are not wedged in either direction. This way they are not stuck in place next time you adjust them. I also just barely snug the retention nuts, They have never came loose between adjustments.
Tom
Are you sure you loosen the right bolt? Sounds like you may have loosen the bolt that mounts the shock to the swing arm. See if this link helps. Else, back to the dealer you go.
Thanks for the responses. Sounds like mine might be stuck in the full soft position -- definitely have about four threads showing. Thanks for that link, too.
Now that I know I'm not crazy, I'll go back and try "unsticking " them.
I had the exact same problem and come to find out they locktite the stud into the plate. To remedy the problem I used a pencil torch on the plate. It took quite awhile to soften the loctite but it solved the frustrating problem.
