A bit of an esoteric question I realize, but I got to wondering where, referencing the bottom frame front shock bolts is the balancing point? I just got my first motorcycle jack and I would like to place the rear-most lift bar just in front of the shocks which puts the front-most lift bar just behind the jiffy stand.
Want this alignment so that I can drain both the engine and transmission oil while on the lift and not risk placing the jack underneath the shocks which do hang down a bit farther than the bottom of the frame, so the jack arm obviously cannot go under them. Thanks.
