removing slip ons from header pipes, HELP!!
Old Feb 16, 2009 | 09:30 PM
6165hd's Avatar
6165hd
Default removing slip ons from header pipes, HELP!!
Wow, those nuts are on tighter than,,,,you know what. Trying to remove the stock slip ons from the header pipes. The whole exhaust is removed from the bike. Probably the first mistake. Well, no going back now....
The exhaust bands are attached with a 9/16" bolt, and a standard craftsman wrench is not budging them, even with Mr. hammer. Screw is to long to us a standard wrachet. So, tomorrow I'm gonna getta a extended version.
I figured from past experience is I may need to heat the bolts, well, no luck this time.
Lessons learned, and imput.... before I throw them through a window.
ha, ha, ha...... Im no wrench.....but havin a blast learnin.............thanks for any feed back.
Old Feb 16, 2009 | 09:47 PM
crazybastid83's Avatar
crazybastid83
You will need a deep set socket. Once you loosen the torca clamp, move the muffler up and down to open up the split in the muffler ends.
Old Feb 16, 2009 | 09:58 PM
6165hd's Avatar
6165hd
10-4 on the deep socket......... Crazy bastid, thanks for the help man!!!
Old Feb 16, 2009 | 10:01 PM
crazybastid83
At work I use an air ratchet, makes things so easy. I would hate to have to go back to primitive tools again, lol.
Old Feb 17, 2009 | 10:25 PM
tk353's Avatar
tk353
if it is off them maybe air wrench from your local mechanic. I am sure on a friday after work they will remove them for a sixpack
Old Feb 18, 2009 | 07:01 PM
bikermike2's Avatar
bikermike2
for stubborn bolts i give then a crack. on top with a good size punch & hammer. just a fast quick tap to break the seal.not to hard to break it thought. works for me every time.its just what i do if not comfortable with this don't do it. i wouldn't do this on engine bolts.
papascull
Oct 13, 2010 08:28 AM
neversatisfied
Jul 10, 2010 08:09 PM
tyson
Jun 2, 2010 07:30 PM
hertiageman
Jan 25, 2010 11:51 PM
Tarponrod
Exhaust System Topics
Mar 19, 2009 12:39 PM
