help! microfiber burned onto exhaust :(
Old Feb 18, 2009 | 06:30 PM
mdemers883's Avatar
mdemers883
Default help! microfiber burned onto exhaust :(
Well, the good news is I have a new set of Hooker Troublemakers installed...bad news is, when I was wiping down the oil tank my microfiber cloth touched the pipes and melted on to it. I know I used some stuff back in the day that took it right off, but I can't remember what it was. What do you guys use for this sort of mess up. Any recommendations will be greatly appreciated.
Thanks!
Old Feb 18, 2009 | 06:49 PM
frankiefire702's Avatar
frankiefire702
I used flitz metal polish when fiber melted on my pipes. With some elbow grease came out fine.
Old Feb 18, 2009 | 06:54 PM
SuperG's Avatar
SuperG
Try some paint thinner. That should work, just let the pipes cool.
Old Feb 18, 2009 | 07:13 PM
crazybastid83's Avatar
crazybastid83
Acetone (nail polish remover)
Old Feb 18, 2009 | 07:24 PM
nowbmw's Avatar
nowbmw
i use 0000 steel wool and it doesnt leave scratches, some say easyoff oven cleaner but i have never tried, i got boot and microfiber off with the super ffine steel wool.
Brent
Old Feb 18, 2009 | 07:28 PM
bloomington g's Avatar
bloomington g
Brent
+1 on steel wool. Use it wet.
Old Feb 18, 2009 | 07:43 PM
utz's Avatar
utz
My buddy had the same thing happen a few days ago a little steel wool took it right out.
Old Feb 18, 2009 | 09:12 PM
cosshog's Avatar
cosshog
Easy off oven cleaner cold comes in a blue can. Make sure pipes are completely cool spray on let set for several hours come back and start rubbing off with nevr dull. I had to repeat this process 2x but with patience the marks came off and you can not tell where they were.
Good Luck
Old Feb 18, 2009 | 10:03 PM
6165hd's Avatar
6165hd
Burned my pant leg on the pipes, and used w-d 40 when the pipes where cool.... give a good shot of the w-d to soak the fiber. If its not coming loose, spray it, let it soak. Eventually it loosens up.... Start the bike , and try to use a rag lightly sprayed with w-d and quickly wipe the area, it will smoke, but it gets the crap off.
Old Feb 18, 2009 | 10:11 PM
Carmell RKC's Avatar
Carmell RKC
+ 1 with the Easy Off oven cleaner, very little risk of scratches.
