Progressive Front Drop-in Lowering Kit?
Old Mar 2, 2009 | 02:44 PM
Jeffs FRC's Avatar
Jeffs FRC
I just installed arlen ness dampers (-2.5") a couple weeks ago on my 08 train. You must remove forks to install any kind of lowering kit on a softail, or at least lower them down some to remove the spring plug to get at the spring
Lowered mine about 2.5" in the rear and 2.5" in the front running heavy oil. Took it out for a short ride the other day and the ride is great. You can get these dampers for about $50. Nice cheap way to lower the front...
Old Mar 2, 2009 | 02:52 PM
Jeffs FRC's Avatar
Jeffs FRC
Originally Posted by refuzeandrezizt
I would think it would be easier to just undo the pinch bolts on the trees and slide the forks down a bit instead of taking the triples apart. Oh well, more than one way to skin a cat huh . I was going to undo the brake caliper and just slide both forks down together with the wheel and all still attached. May not work, but I was going to try it.
I agree on taking the trees apart. Seems like more work.
Your way would work but your probably gonna need another set of hands. Also if you want to get the lowers PC'd, now would be the time since it wont be all that much more work to yank those while you do the lowering kit.
Old Mar 2, 2009 | 03:40 PM
DECON BLUE's Avatar
DECON BLUE
Thumbs up
If your going to lower the fork tubes you will have to remove the top caps before you can loosen the pinch bolts to slide the tubes down. Your not doin anything with the dampers with the Drop-In Progressive Kit. Just installing the springs, compensator springs, PVC tubes and washers. It's just not as hard as everyone is making it out to be. IMHO.
Old Mar 2, 2009 | 04:18 PM
refuzeandrezizt's Avatar
refuzeandrezizt
I agree, I think it will be pretty easy to do. I ordered the progressive kit today and should have it in a few days. We shall see I guess. I just don't understand why the progressive site, and Dennis Kirk, both say that the drop in kits are available for us Train owners, when they won't be true "drop ins" like they are claiming. I guess they are still drop ins though, either way that it has to be done.
Old Mar 2, 2009 | 04:20 PM
refuzeandrezizt
Thanks for the info. I do plan on either painting or powder coating the lowers, but I haven't made up mind yet if I want gloss black or flat black, or if I will paint or pc them.
Old Mar 2, 2009 | 04:24 PM
refuzeandrezizt
So I have a question then. Should I have went with the Progressive cruise control lowering kit instead of the drop in kit? I could of saved myself about $20 dollars with the cruise control kit. Since the drop in kit isn't really a drop in kit, I think they would both install the same way. Just throwing it out there.........
Old Mar 2, 2009 | 04:31 PM
Blk and Chrome's Avatar
Blk and Chrome
I know what you mean, I was thinking the same thing as I have some chrome lowers and right now thinking I will just ride it thru the summer and then redo next winter. No it is easy not that hard a deal to do, Can't wait till its done and yes pics will be posted
Old Mar 2, 2009 | 05:58 PM
klf33's Avatar
klf33
I have a set of springs that arrived already from Ebay,
I also have new Black out lowers and baught Rubber Gaiters to add the 'bobber' look.
So, when I am done, I will have a full assembly of 2"+ tubes/lowers for sale .
And will post pictures too, my back is down 1.5" already.
The reason for lowering is that I am installing also a black out Z 12" apes in the front, they look so sweet, but won't fit will with the 2"+ fork tubes IMHO.
Pictures will be posted once the job is done.
Old Mar 4, 2009 | 08:17 AM
chidiver's Avatar
chidiver
UPS is scheduled to come today. My spring kit shows "Out for Delivery." If they do their part, hopefully I'll be able to spend some quality time out in the garage this afternoon.
Old Mar 4, 2009 | 09:03 AM
refuzeandrezizt
Me too!! I'm so excited, but it will probably be this weekend before I can get to it. I plan on riding the rest of week as it is suppose to be in the 60's here the rest of the week .
