SE screamin eagle pipes / baffles
Old Mar 10, 2009 | 11:22 AM
Strick's Avatar
Strick
Default SE screamin eagle pipes / baffles
Can you remove the baffles easily on the screamin eagle pipes? There are two bolts on each pipe that seems to hold in the baffles, but when I took the bolts out and tried to get them out they would not budge.
Are these pipes designed for the baffles to just pull out? If yes, maybe I just need to use a slide hammer.
Thanks guys!
Old Mar 10, 2009 | 05:06 PM
nowbmw's Avatar
nowbmw
Slide hammer tapped mine right out, tried pulling them and no budge but the slight impact of slide hammer they came rigt out.
Brent
Old Mar 10, 2009 | 07:58 PM
AR-15 DEUCE's Avatar
AR-15 DEUCE
My .02... leave them in and just drill a one in. hole in them they will sound great,also they will keep some backpressure in, and you wont get a bad decel pop..also keep the LE off you !!!
Old Mar 11, 2009 | 05:53 PM
tk353's Avatar
tk353
get some hookerpipes.com or rush slip ons and choose the baffle size you like
Old Mar 12, 2009 | 12:36 AM
Strick's Avatar
Strick
Thanks for the replies. I have already pushed the diffuser (?) back about 1/2 way from where it was stock versus fully open. I am not a fan of the look of SEs (on a heritage), but I don't know if I want to buy new pipes just yet.
I think I will push it the rest of the way in to make the pipe a straight through pipe with the baffles in. I know on dirt bikes that is all the mufflers really are and they are definitely quieter than a straight pipe. If the sound is still not enough, I will pull them out with a slide hammer.
Old Mar 12, 2009 | 08:16 AM
Chief101's Avatar
Chief101
Try a set of Thunder Monster baffles in 'em
Old Mar 12, 2009 | 07:40 PM
TedMan's Avatar
TedMan
Ted
Old Mar 12, 2009 | 08:29 PM
conroskie's Avatar
conroskie
conroskie
freebyrd
Jan 9, 2009 07:52 PM
dennis_dicks
Jul 29, 2008 05:42 PM
giovex
May 22, 2008 02:23 PM
newby
Dec 10, 2007 03:15 PM
Cowracer
Feb 19, 2007 05:14 PM
