Measurement Help
Old Mar 17, 2009 | 11:36 AM
1 New Softail's Avatar
1 New Softail
Default Measurement Help
Can someone with a detachable sissy bar on a 06 or later FX Softail please measure the the distance between the the plates. I also need the distance from the center of the two holes. The second measurement would be just measing the distance between the holes on one of the detachable brackets. The first measurement is inside of one plate to the inside of the other with the bar attached. This must be off of a bike with the 200 rear. Thanks
Old Mar 17, 2009 | 12:57 PM
Mordrapheus's Avatar
Mordrapheus
and would you like a coffee with that?
lol
I would love to help but I just don't have that 200 rear tire...everything else I could measure for you.
what you trying to do?
Old Mar 17, 2009 | 02:32 PM
1 New Softail
looking to get a detachable sissy bar. I'm looking to buy one of the sissy bars that someone is not sure what it fits. Thought info would be helpful..
Old Mar 17, 2009 | 03:26 PM
Mordrapheus
do you have a sissy bar on the bike at the moment?
or do you have a custom rear fender?
if you have an existing sissybar mounted and the fender has the standard holes the plates and bolts of the detachable kit will just fit right on, replacing the existing plates and bolts.
If you don't have a sissy yet, then you just need a sissybar that fits your tire size, the holes should be standard.
now if you have custom fender with no holes and so forth then it will get a lot tougher.
when I get home I will check out my service manual and see what it says about the measurements.
Old Mar 17, 2009 | 04:40 PM
1 New Softail
I found one that someone has for sale. They aren't sure what it fits. I have measured the stock custom sissy and it is close. I want the measurements from someone that has a detachable on a 06 or later FXST
Old Mar 17, 2009 | 07:04 PM
Mordrapheus
I think it should work...ask them what their return policy is
sorry wished i could help more
Old Mar 17, 2009 | 08:11 PM
gwalsh's Avatar
gwalsh
The distance from center of one hole to the center of the other on the mounting points is 10 1/4"
The distance from inside to inside of the detachable bracket is 11 1/8" Outside to outside is 11 3/8"
This is on my 2007 FXST.
Old Mar 18, 2009 | 07:44 AM
tk353's Avatar
tk353
'00-later FXST, FXSTB, FXSTS, FXSTSSE/2/3, FLSTFSE2, FLST, FLSTF, FLSTN, FLSTSB, FLSTSC
Old Mar 18, 2009 | 01:23 PM
1 New Softail
Thanks gwalsh..Thats what I was looking for
Gee
May 25, 2014 07:27 PM
bikerlaw
Jun 10, 2012 01:35 AM
SIM
Aug 7, 2007 02:45 PM
sims5
Jun 1, 2006 12:34 AM
english
May 2, 2005 08:53 AM
