Aux Lighting Fatboy
Old Mar 22, 2009 | 09:34 PM
gary1hd's Avatar
gary1hd
Default Aux Lighting Fatboy
I purchased used Aux Lighting for my 07 Fatboy. No instructions were included. I need some help with the wiring. The wiring has two connectors, do these plug into existing connectors under the gas tank?
Old Mar 23, 2009 | 08:05 PM
snip0721's Avatar
snip0721
Default aux lamps
they go to the togle switch, usually mounted on the l.r. tin. ground is made through the mounting stud. power to the togle is picked up from the low beam wire (o.e) most opt to pick up power from aux. fuse under the seat. this also allows you to run aux. lamps with either high/low beam. i've got 2000 schematics if you need. pm me your e-mail, and i'll scan and send. steve
Old Mar 23, 2009 | 08:50 PM
wildman67's Avatar
wildman67
you have to plug into the toggle switch, you also have to tie into your yellow headlight wire. the schematic says to do it into the headlight. I lifted my tank and did it underneath, it was easier. shovelhead bob (a moderator on this site) helped me do mine. GOOD LUCK!
Pyrotag
Apr 17, 2014 12:56 AM
joflewbyu2
Electrical/Lighting/Alarm
May 2, 2011 02:19 PM
shimmon
Aug 8, 2008 05:08 PM
dynamac
Dec 10, 2007 11:02 PM
Inforit
Feb 6, 2006 01:25 AM
