Mounting a flush gas gauge (with pics)
Old Dec 14, 2010 | 02:55 AM
  #41
cmcarr88's Avatar
cmcarr88
thanks for the info ... fixing to change mine out this weekend ...
Old Dec 14, 2010 | 08:37 AM
  #42
cwsharp's Avatar
cwsharp
Don't worry about the light color... it won't be long before they aren't working anyway. Then you can just paint the dots on top in any color that you like and use your tripmeter.
C#
Old May 8, 2013 | 03:37 PM
  #43
Axxehead's Avatar
Axxehead
Stage I
Default 2009 Rocker install
Thanks for the instructions & photos. I have a 2" tank lift so the connector was real easy to get to. Disconnected the neg. battery. Didn't need to mess with anything else. Ended up just cutting the old wires off above the connector to pull out the old fuel gauge. Doubt if I'll ever go back to stock. BTW my part is #75020-08C. We'll see how the LED lights hold up.
Old Jul 2, 2013 | 07:32 AM
  #44
Arizona Sage's Avatar
Arizona Sage
Great post! Thanks for sharing. I've got an 07 Road King with this setup and have a question I'm hoping you or someone else can answer. I was leaving work yesterday (Phoenix, AZ) and noticed the LED gauge had popped up, as if the springs gave way inside. Didn't affect the ride or anything but wondering if the bike being outside in the heat may have loosened or triggered this? After I got it home and found your thread, I gently pressed it back a few dozen times and it finally "clicked" and stuck. Now I'm paranoid about it. Any reason I should need to take further action?
Thanks, from a noob.
Old Jul 2, 2013 | 08:02 AM
  #45
jcallesano's Avatar
jcallesano
HI
It is possible for these to "disengage". Mine has done it
If you've ever looked at the mechanism that secures this you will see that it has to be pushed down and under a tab that hold it in place. It has to be perfectly pressed down and clicked into place for it to not move. Mine was misaligned and I chewed the plastic part in my housing. Still works though and stays put. Click it up and check to make sure nothing looks like its broken. If the tab gets out of shape, since its plastic, it can cause it to come loose. I had to do the same exact thing as you, press it several times until its secured in place. If you have more problems and its under the year time period you purchased it...warranties are a good thing so I advise you to take advantage if needed.
Hope this helps.
jc
Old Jul 2, 2013 | 08:14 AM
  #46
fatboy1729's Avatar
fatboy1729
I know this thread is a few years old and am sorry if it seems that I did steal it. I just had a quick question. I sent the op of this thread a message and I am hoping he sees it. I already have the flushmount kit installed now. My question to him is how hard will it be to remove the flushmount kit and swap it over to another tank same year and model? I did not do the install. Thanks for anyones time and advice...
Old Jul 2, 2013 | 08:21 AM
  #47
NDBadlands4-2's Avatar
NDBadlands4-2
this is a good thread to resurrect. I have seen those flush mounts before, but thought that the install was much more complex. I missed this thread first time around.
Old Jul 2, 2013 | 08:43 AM
  #48
Arizona Sage
jc
Thank you for your quick response. I bought the bike privately a year ago so no warranty. It also reads at 2 lights all the time now, no matter the fuel level. I've just gotten used to using my trip-ometer to gauge my fuel level but am curious if there's an easy fix for that? If not, I'll just deal with it the way it is until I have the $ to get it fixed properly.
Old Jul 2, 2013 | 11:00 AM
  #49
steamybob's Avatar
steamybob
A great looking mod even if it is a tad expensive (Ł200 for us limeys!).
Old Jul 2, 2013 | 01:48 PM
  #50
a99miata's Avatar
a99miata
excellent job...can I come over on saturday and have you show me again? lol
