exhaust leak
Old Mar 25, 2009 | 10:13 PM
tk353's Avatar
tk353
i changed the gaskets because they came with the pipes. i would have broke them if i stored them.
Old Mar 25, 2009 | 10:21 PM
tlb's Avatar
tlb
It came new from the dealer back in 06 with the pipes. Therefore, I do not know.
When I pulled them to install the clutch cable, I did not replace the gaskets. I asked several guy to include an HD mechanic if I needed to and they all said, no. but then I have not had the problem since I reinstalled them, it was before.
Originally Posted by wildman67
did you change the gaskets when you changed your pipes?
Old Mar 25, 2009 | 10:26 PM
azfathog17's Avatar
azfathog17
I have torqued my header bolts 2X since I installed the pipes about 3k mi ago. I think I torqued them at 500mi post install and they did not move much before the wrench clicked. The second iteration yielded little movement and I have no leaks. I will probably not check them again until 10k. Have about 5300 on it now.
Old Mar 25, 2009 | 10:28 PM
wildman67's Avatar
wildman67
just as a place to start then I would try replacing the gaskets! worth the few bucks in my opinion!
Old Mar 25, 2009 | 10:34 PM
tlb's Avatar
tlb
It is not leaking anymore, the problem was the nuts themselves were not torqued when I removed the pipes. Just stating, I did not realize I had an exhaust leak and I will check the exhaust flange nuts for now on when I service the bike. However, you are correct if it is an on going issue of them coming loose I will replace the gaskets.
Old Mar 25, 2009 | 10:57 PM
gaffster01's Avatar
gaffster01
I put new pipes on 07 Sporty, and two 08 Bones in the last 2 weeks and none of them had torqued down flange bolts. I am going to check mine at 100 miles and again at 500 with the new pipes to be sure I dont get any leaks.
Old Mar 26, 2009 | 12:15 AM
JayDee5150's Avatar
JayDee5150
Originally Posted by snip0721
i switched over to stainless steel flange nuts. nut w/serated washer made on. no loose, no rust. flange makes installing the rear, easy with a 1/4" drive shallow socket.
Those are nice...thats a great idea...I might have to be a copy cat!
stbobshadow
Oct 26, 2011 07:40 PM
firefightermike
Sep 25, 2011 09:49 PM
otter8
Mar 29, 2011 06:09 PM
snookums
Sep 7, 2010 01:27 AM
Adam_T
Sep 28, 2009 03:07 PM
