billet headlamp hi/lo reversed.
Old Mar 27, 2009 | 09:20 PM
20FXST06's Avatar
20FXST06
Originally Posted by Denim Nightrain
A friend of mine bought the 4 1/2" headlamp from Harley for his 08 Nightrain. One of the terminals within the housing has melted and shut down twice in a few months. Bad ground, or what?
Sounds like he may have a bad ground. Also may want to replace the wires with a little heavier gauge wire.
Old Mar 30, 2009 | 09:25 AM
Denim Nightrain's Avatar
Denim Nightrain
2nd Gear
Default It worked.
Swapped the yellow and white in the housing. Working great now, thanks guys.
Old Mar 30, 2009 | 11:44 AM
In Memoriam Citoriplus's Avatar
May our Moderator Rest in Peace
Ususally the connection that gets 'cooked' is the problem becasue its either loose or corroded. Either condition generates heat, and left long enough it can and often does melt things.
Best bet is to get hold of some Tarrn-X silver/brass cleaner to clean off the corrosion. Use some pliers to make sure the terminal fits tightly. Then liberally coat the terminals with dielectric grease to prevent it from corroding again.
Deuced69
Aug 18, 2017 02:34 PM
leeuw888
Apr 13, 2011 06:50 AM
03duece
Dec 24, 2007 02:01 PM
JCM800
Mar 11, 2007 03:34 PM
Jezcruzen
Aug 20, 2006 08:25 PM
