Replacing Drive Belt on 03 Fatboy
Old Apr 30, 2006 | 10:10 AM
Ripken2131's Avatar
Ripken2131
2nd Gear
Default Replacing Drive Belt on 03 Fatboy
I just joined the forum and just purchased an 03 Fatboy. Drive Belt snapped on me. Is this a job I can do or should I leave it to the dealer. Where could I find the instructions from the service manual? Haven't had time to purchase the manual yet but want to get back riding quickly.
Old Apr 30, 2006 | 12:21 PM
1941ratrod's Avatar
1941ratrod
Default RE: Replacing Drive Belt on 03 Fatboy
You better get a service manual first its a pretty easy job but you have to damn near dis assemble the whole bike. take off the oil bag, starter, outer primary cover, primary drive set, and the inner primary, make sure you replace the seals and gaskets. It sounds hard but it really isn't I can pull my entire primary off and get it back together in around 3 1/2 hours. Just read the manual then read it again before you start because every thing has to come off in order then go back ithe same way only in reverse or you will be pulling your hair out. the best tip is to Read Read Read
Old Apr 30, 2006 | 02:02 PM
Ripken2131's Avatar
Ripken2131
2nd Gear
Thanks.
98hotrodfatboy
Sep 10, 2015 11:17 AM
Chopper Nate
Nov 29, 2014 11:39 PM
bigace65
Mar 20, 2011 04:11 PM
pearson
Mar 25, 2009 12:26 PM
SemmesSporty
Nov 12, 2007 08:29 AM
