driver belt
Old Mar 18, 2011 | 07:11 PM
bigace65's Avatar
bigace65
Stage II
Default driver belt
i need help!!!!!!!!!!!!!!!! that the best way to change the driver belt on a roadking
Old Mar 18, 2011 | 07:15 PM
Jackie Paper's Avatar
Jackie Paper
Community Influencer
If you need to ask, take it to a dealer. Its a big deal. You need service manual, special tools, primary locker and transmission locker. 200lb torque wrench, special sockets, 700 lb inpact, inner primary and rear wheel needs to be removed. It is a pain for a first timer.
Old Mar 18, 2011 | 07:16 PM
103 sedona orange's Avatar
103 sedona orange
If you don't have a HD Service Manual then you should buy one before starting!!!! It's all in there. But I'm sure someone can give you a few tips. good Luck
Old Mar 18, 2011 | 07:27 PM
bagga's Avatar
bagga
when i replaced mine it took 18 hours to do it. that's counting running around looking for parts and tools. reading the manual and figuring it out was 3-4 hours. actual work time was about 10 hours. i didn't bust my *** because i wanted to get it right.
Old Mar 19, 2011 | 04:25 AM
emwolb's Avatar
emwolb
welcome to the forum big ace 65, yeah, all of the above. it's a pretty tough job for someone who hasn't been into the primary side of our motors. the cost of the compressor, impact, sockets, etc, ya see where this is going? you might be better off taking it to a competent indy or even harley to get it swapped out. as i get older i realize that work is highly overrated, so i usually turn this sort of work over to someone who's done a bunch of them. i have all the necessary tools, but i'd rather be riding than wrenching. good luck with your drive belt.
Old Mar 20, 2011 | 03:53 PM
bigace65's Avatar
bigace65
Stage II
thanks 4 the info i havn't started on it yet but i think i'll take to the dealer if it's that much work
Old Mar 20, 2011 | 04:11 PM
Beemervet's Avatar
Beemervet
and you are changing it why?
yorgle7
May 5, 2014 05:25 AM
jimdog1356
Jun 10, 2012 06:15 AM
952dave
May 14, 2012 01:19 PM
AlleyKatt
Nov 10, 2009 06:30 PM
hotrodrobert
Nov 5, 2006 12:12 AM
