Passing lamp bulb replacement??
Old Mar 7, 2011 | 03:29 PM
kjkustoms's Avatar
kjkustoms
Default Passing lamp bulb replacement??
Trying to find a better quality passing lamp bulb, the stock HD bulbs look awful yellow compared to the PIAA H4 in my headlight. Any one running anything different. I know the stockers are 35watts, can you run 60 watts? without problems with overheating ? Any other options, I see LED bulbs are out there, they are pretty reasonable, anyone have any reports on using these? Feedback would be greatly appreciated.
Old Mar 7, 2011 | 03:38 PM
frenchbiker's Avatar
frenchbiker
Yes there are other options. I'm using 35W amber sealed beams in mine. Studies show that amber lights are more visible in a sea of white lights than white. They exist in white too if you prefer.
Here is a pic.
Old Mar 7, 2011 | 04:38 PM
pargenz's Avatar
pargenz
I got a pair from Walter's Workshop ($25 for the set). They are white (in the 4100K range).
http://www.waltersworkshop.com/passing-lamp-bulbs.html
Old Mar 7, 2011 | 04:42 PM
Uncle Larry's Avatar
Uncle Larry
Thanks for the link for the lights.
Old Mar 7, 2011 | 04:45 PM
sooey's Avatar
sooey
What about LED options anyone? I was thinking that might be an option.
karbar99's Avatar
karbar99
Why not just go with the PIAA bulb in your passing lamps now. If I remember correctly it's the H3 if it's not the sealed unit.
Done this (PIAA's in all lights) in a previous bike and they were bright!
Old Mar 20, 2011 | 01:31 PM
MJMagruder's Avatar
MJMagruder
I'm wondering about upping the wattage from 35 to 55 as well... It's harder to find the 35 watt H3 bulbs as well.
Ditto on wondering about the LED H3 replacement... anyone running them? I'd like to know about the brightness compared to a 55 watt bulb.
Thanks!
Old Mar 20, 2011 | 02:49 PM
Tx_Rider's Avatar
Tx_Rider
I switched to LEDs
Old Mar 20, 2011 | 02:59 PM
bigdady's Avatar
bigdady
do you have a part# for those led passing lamp bulbs also did you have to install anything else
Originally Posted by Tx_Rider
I switched to LEDs
Old Mar 20, 2011 | 03:07 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
You can just pull out the old bulbs and put some 55W bulbs in. They are $3 each at any auto parts store. Harley wioll try to sell you whole sealed piece, but you can pull the rubber casing off teh back to access the bulbs very easily.
Drew
